FrankenIntake: Dip in Power problem
Old Aug 16, 2002 | 06:43 AM
Capitone's Avatar
Anyone with the frankenCar intake notice a "dip" in Rpms and torque when you reach around 60 mph? I've noticed since I've had the intake (Im auto) that the car pulls pretty hard under WOT up untill around 60mph then I get this weird "dip" in power and sound. The Rpms dip about 2 checks, as does the Speedometer i.e.: Goes from 62-60 for a second then begins climbing again with no problems. Anyone else have this happen? This is my first intake so Im not sure if this is normal. I ran a search on this but could did not pull up any similiar problems. Anyone?
Old Aug 16, 2002 | 01:19 PM
Capitone's Avatar
Anyone?
Old Aug 16, 2002 | 02:31 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
ive got a berk with a franken pipe. i cant imagine that the filters are that dramatically different. i dont have any loss in any part of the power band. i didnt lose any low end and only picked up up top. when its real hot outside there is a noticeable lag but i expect that.
Old Aug 16, 2002 | 04:43 PM
02maxima's Avatar
i have it too but i have a home made cold air intake .my happens in 3rd.auto gear at about 80 mph only the rpm drop two clicks
Old Aug 16, 2002 | 05:12 PM
SR20DEN's Avatar
VQ Wizard
Look at the dyno charts for any VQ35DE and you'll see it. Franken car doesn't cause the problem. The engine does that naturally. The new intakes just amplify the problem slightly.
Old Aug 16, 2002 | 06:06 PM
djPlayboy's Avatar
yeah what he said... also if your in a 2k or a 2k1 auto you may notice the problem, if in third gear with OD off while at 80 or 85 at about 4k rpms. But to remedy the problem turn OD back on, plus if your at full throttle at 4k and turn it on watch the needle hit 5500 real quick try that... hel my car might just be wierd...
Old Aug 17, 2002 | 01:18 AM
NightRider's Avatar
Hmmm....why didn't anyone believe me when I posted this trick?
Old Aug 17, 2002 | 02:51 AM
Frank Fontaine's Avatar
Usually aftermarket products take up slack or deficiencies made at the factory. This one amplifies the problem? Do you at least get the chicks that the banner on the web pages shows?
Old Aug 17, 2002 | 07:15 AM
SR20DEN's Avatar
VQ Wizard
I don't have a Frankencar intake. I have something that I got off ebay. The Frank isn't the only intake that does it. ALL of them do.
Old Aug 17, 2002 | 07:29 PM
Capitone's Avatar
Cool! Like i said, Im sort of new to intakes, so i wasn't sure if this was normal not. Seems that is, so cool.... Thanks for the feedback.
lowpost99
Oct 26, 2025 06:53 PM
adamgalazka
Feb 5, 2023 08:24 AM
The Frye
Feb 3, 2019 08:34 AM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
