Center bore, hub bore, blah blah blah. (Wheel question)
Old Aug 16, 2002 | 01:07 PM
Remington's Avatar
Alright, I've got a '96 max SE. It has '98 SVT Cobra wheels on it. From what I've gathered, the hub bore for the max is 66.06mm. Hub bore for a mustang is 70.5mm (I'm assuming the wheel center bore is 70.5 as well). I've got a vibration that I can't get rid of and I'm assuming it's because I need hubcentric rings. Problem is, I can't find the right size. Closest one is a 66.06 to 71.12mm. Will this work? Could I shave some off the ring to get it to work? Or should I go to a machine shop and have them drill out the wheels to 73 or 74mm beacuse I can find hub rings for that? How much would this cost and is it worth the hassle? Thanks for any insight.
Old Aug 16, 2002 | 01:17 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Only 2 days ago:
http://forums.maxima.org/showthread....stang+hub+ring
Looks like there are a couple of possibilities in there.
Old Aug 16, 2002 | 01:23 PM
Colonel's Avatar
Old Fuddy Duddy
OK
Yeah, hubcentric rings are the way to go....solved my vibration. Also me taking the time to properly mount the rim to the axle.
I would personally buy the plastic ones (like 5-8 bucks for whole set)from like DiscountTire and carefully shave them so that fit is VERY SNUG in the rim. But you have to make sure that you can sand/shave them in a perfect circle. Carefully mount the rim making sure that the lugs are perfectly centered and drive.
If vibration goes away...you are golden and can consider having custom ones made or shaving the rim or whatever. I would make sure your rims are perfectly balanced before you try this.
I personally would not have them drill out the wheels. I am not a metalurgist (sp?) but that might effect the integrity of the rim itself.
Old Aug 16, 2002 | 01:47 PM
Remington's Avatar
Thanks guys. I've always been very careful when putting the rims back on the car and tightening in a star pattern. It just seems to me that by doing this and having acorn style lug nuts, the wheel would be centered and the hub ring really wouldn't do much of anything.
Old Aug 16, 2002 | 01:59 PM
bill99gxe's Avatar
Yeah, it's odd that some stupid circular rings can get the vibs down, but it definitely helped in my case.
In your case, you may be best served by the plastic type rings as Colonel stipulated above......that way you can shave it down "perfectly".
Maxima_Joe
Nov 25, 2015 08:19 AM
Maxima_Joe
Oct 15, 2015 08:01 PM
homeyclaus
Sep 3, 2015 06:15 PM
tnewbs
Aug 28, 2015 10:15 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
