ok.. VI/RPM switch help
Old Aug 20, 2002 | 03:04 PM
Bags's Avatar
VG Ridah's Biatch Hoe
Ok I am checking my VI to see what, if anything is not working.
The harlan RPM switch is perplexing me right now. The light comes on at my set RPM, but I am checking the voltage and it is going to .65 VDC
Before the light comes on it is at .85-.65 VDC
So I am kinda shaking my head right now.
How much voltage is supposed to be there?
I have not used a 30 amp relay.. I am just trying to see if it is working.
EVERYTHING else works.. except this.
ANY help would be great
AM I confused about the relay? Does everyone hook GND up tp the relay and use the RPM switch as a GND to the MAP/BARO switch with a constaint power source?
thanks
bags
Old Aug 20, 2002 | 03:42 PM
speedtrip's Avatar
Re: ok.. VI/RPM switch help
thanks
bags
The GND prong on the relay should be connected to the switched ground from the rpm switch. The 12v wire from the Map/baro switch should be connected to the 12v out prong on the relay. I have a picture if you need it. PM your email address if you need it.
Old Aug 20, 2002 | 04:07 PM
Mishmosh's Avatar
The Harlan is a switched ground meaning you should get an open circuit until the set rpm is reached, after which the white wire becomes ground (~0 VDC).
The relay serves to convert the switched harlan ground to a 12VDC line when activated. The other input to the solenoid is then ground.
As long as the harlan LED lights appropriately, go ahead and hook up your relay. You will be able to hear it click when the Harlan activates it and it may be simpler for you to measure the 12VDC that it puts out when activated.
Old Aug 20, 2002 | 04:37 PM
Bags's Avatar
Thanks guys. I DID NOT read everything closely enough.
I figured it out about 5 minutes after I posted..just got back from radio shack and the diagram on the back of the relay confirms what I just figured it out.
READ ALL DIRECTIONS.
I did not read all of the RPM switch direction therfore I did not fully understand what the heck I was doing. Buring my hand multiple times did not help.
Anyway thank you for the slap in the face and the help..
See ya in about an hour with a working VI
Old Aug 20, 2002 | 09:23 PM
nismo2020's Avatar
Needs non-Maxima Friends
ya rat bastard is it working?
Old Aug 21, 2002 | 03:46 AM
redmaxpa007's Avatar
i SeE what you did therE
bbwhahha
damn you.. tell us if it is working or not??
Old Aug 21, 2002 | 10:53 AM
Dave B's Avatar
Not DAVEB the parts guy
thanks
bags
I hope you didn't fry the RPM switch because Harlan's directions specifically say not to use the RPM switch as a ground for a solenoid. This is why you must run a relay.
Dave
Old Aug 21, 2002 | 05:33 PM
Bags's Avatar
Re: Re: ok.. VI/RPM switch help
Dave
Nope did not fry it. The ground was bad... 2 bad grounds actually.
Thanks for all the help dave B...mishmosh..speedtrip
there were several problems including a corroded splice.
I broke the check valve port on the vaccum canister..so tomorrow I will attempt to have a working VI
Thanks agin gentlemen for all the help
carl&007 I'll try again tomorrow
Old Aug 21, 2002 | 06:32 PM
Ramius83
Re: Re: Re: ok.. VI/RPM switch help
So you didn't pull an Erik manuever?
Old Aug 21, 2002 | 10:07 PM
nismo2020's Avatar
Re: Re: Re: Re: ok.. VI/RPM switch help
good luck baggy. i think i hope it works more thatn you do.
OT erik you should your sig to say
" three things your 96 auto max DONT HAVE -
100 NOS
5spd conv.
97&up body conv."
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
lrb6805
Sep 24, 2015 05:03 PM
