Finally Started The Rebuilt Motor
Old Aug 20, 2002 | 10:08 PM
i30krab's Avatar
We started up the car today and at first we thought there was a problem with the timing chain tensioners. Then, we discovered that the stock oil pump isn't strong enough to push oil thru the system I have, too many long oil runs. When we bypassed the relocated filter and cooler, oil pressue came back to 45 lbs and the noise disappeared. Does anyone have any suggestions for getting more pressure?
I know one thing, this motor now has attitude at idle. The engine has that high output loping sound from the JWT cams! It really sounds bad ***! We took it for a test ride and the difference in power is amazing. The tires broke traction at a quick half throttle in second gear and that was on a straight away. I will be breaking in the engine for the next 1000 miles and I'm sure there will be many bugs to iron out. I won't be dynoing or going to the track until I take it to JWT for the final tuning dial in.
I'm very satisfied with the way the car runs now and the I30KRAB will be a real sleeper.
By the way, We'll be working on a way to make a removeable bracket piece on the stillen bracket so the damn SC belt can be changed without removing the SC .
Old Aug 20, 2002 | 10:13 PM
Jeff92se's Avatar
I'm needing a caw
Holy crap. Your car gets more crazy by the month. For the oil pump thing, you might want to see if the other stock Nissan oil pumps are stronger. ie.. for the old Datsun L series engines, the 280zx turbo oil pump was rated for a higher psi. So maybe one of the other VQ series oil pumps might be better. ie.. jdm VQ30DET or maybe even a SR20DET or the jdm VQ20det.
Pmp-n8a's Avatar
nice
Old Aug 20, 2002 | 10:19 PM
MaximaRider's Avatar
Sounds F-ing SWeeT!
Old Aug 20, 2002 | 10:46 PM
gtr_rider's Avatar
192.168.1.1
Video, Audio?!?!?! ANYTHING!?!?!?!?
Im getting excited hearing about a beefed up Maxima* VQ
Old Aug 21, 2002 | 05:19 AM
Confused's Avatar
Permanent Maxima.org Resident
Its Aliiiiiive~! Congrats Ron.. come visit, it will be broken in by the time you get here
Old Aug 21, 2002 | 06:56 AM
Lime's Avatar
aww kewl. I wanna see this.
Old Aug 21, 2002 | 07:39 AM
SteveChicagoSC's Avatar
Cool!!!! That new bracket will make things a lot easier!!!
Can't wait to hear the specs on those new cams.
Old Aug 21, 2002 | 08:26 AM
MardiGrasMax's Avatar
H E L L Y E A ! ! ! !
'wipes drool from mouth'
I cant wait to see the numbers either!
Old Aug 21, 2002 | 08:32 AM
furbiss112's Avatar
cam specs
they are 256/.415 from JWT. don't ask how i know but the specs are correct. believe me. later.
Ferhan
Old Aug 21, 2002 | 09:32 AM
CKNY's Avatar
yummy
Old Aug 21, 2002 | 10:21 AM
Nismo87SE's Avatar
An oil pump from a VQ30DET should be beefy enough for your application. I'd like to hear a sound bite of the car with cams.
Old Aug 21, 2002 | 10:28 AM
JUDE's Avatar
That should definetly be good for some low to mid 13s
Old Aug 21, 2002 | 08:03 PM
emax02's Avatar
Good to hear your car is back and working for the most part. I was wondering how much these cams will cost the public and what kind of gains are to be expected?
mvm062
Nov 30, 2020 09:00 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
iflexsteel
Sep 2, 2015 08:04 AM
maxinout93
Aug 16, 2015 07:25 PM
