Maintance wise
Old Sep 2, 2002 | 08:43 AM
PRPmax's Avatar
Maintance wise
Hey fellas,
I need to know what all has to be done a 98 honda civic dx. Maintance wise.. Car has 64k on it now. I'm just going to use this car as to take me back and forth to work. I'M NOT GETTING RID OF MY MAX!!..
But anyways I know civics are fairly easy to work on. So 60k tune up needs to be done.
I got sparks, spark wires,
air filters, fuel filters,
distributer cap and coil,
I'm really not sure on timing belts. But I doubt they need to be replaced. But it looks in good condition / no cracks or slick spots.
What am I missing here?
Thanks,
NeL
Old Sep 2, 2002 | 01:35 PM
karguy's Avatar
Re: Maintance wise
Originally posted by PRPmax
Hey fellas,
Thanks,
NeL
Clean / change PCV valve, install new distributor rotor button, change tranny fluid, flush radiator and install new antifreeze, check brakes and flush brake fluid. The timing belt doesn't have to be changed until 100k, I also put 6 ounces of Redline Water Wetter in new antifreeze.
Old Sep 2, 2002 | 01:52 PM
Green 2kSE's Avatar
Re: Re: Maintance wise
That's good advice. Depending on how the car was treated before you bought it, you may need to clean the throttle body and inspect CV boots (mine cracked before 60k). You may also check the valve clearances (it should have been checked at least once already).
Old Sep 3, 2002 | 04:14 PM
PRPmax's Avatar
Thanks for all the input guys.
Mahmuth
Aug 16, 2024 08:23 PM
Heat0212
Oct 24, 2020 12:36 AM
14GmMax
59
Aug 4, 2019 11:26 AM
ToTheMax305
Sep 23, 2015 09:11 PM
JoshG
51
Sep 21, 2015 10:41 PM
