Check that tire pressure!!!!
Old Sep 3, 2002 | 06:04 AM
Lovejoy's Avatar
I was going to go out for a drive this weekend and decided to check the tire pressure. Whipped out my accugauge, and was suprised. I waws down 5 lb's per tire!! I normaly run 38F and 35R. Inflating the tires to my specs REALLY made the difference. I hadn't really had a chance to drive in a while and the Max has been feeling like a pig lately, and cause I hadn't checked the tires in a little while (lazy). The turn in is razor sharp, and corners are like rails. So check those pressures!!
Lovejoy
Old Sep 3, 2002 | 07:26 AM
Nore474's Avatar
what do you keep your Tire pressure at 32psi?
Old Sep 3, 2002 | 07:44 AM
Lovejoy's Avatar
I keep the fronts at 38 and the rears at 35.
Lovejoy
[edit] I am running Bstones' RE730's at 235/45/17
Old Sep 3, 2002 | 07:48 AM
88MaximaSE's Avatar
all nissan cars are at 32 psi from the factory
Old Sep 3, 2002 | 08:32 AM
92vemaxse's Avatar
I believe mine is 26 psi from the factory.
Old Sep 3, 2002 | 09:15 AM
patel_anu's Avatar
26 is pretty low, mines 32 from factory
anu
Old Sep 3, 2002 | 10:42 AM
sinewave's Avatar
The label under my center console lid says 29 p.s.i. front and rear. I use 29 for around-town driving; 32 for road trips and 40 for autocrossing.
Old Sep 3, 2002 | 11:18 AM
2k2kev's Avatar
It's chrome alright...
mine were all different, between 28 and 36 from the factory... factory might recommend 32 but that's not what they're delivered with.
I drive all highway so I keep mine a little higher (34) but good advice, everyone should check tire pressure regularly... better handling and saves gas.
Maxboy23
Sep 8, 2015 06:53 PM
02nissmax
Sep 5, 2015 01:50 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
gizzsdad
Aug 19, 2015 01:01 PM
acw
Aug 13, 2015 12:50 AM
