All Pop-Charger Owners- No Bracket?
Old Sep 3, 2002 | 01:16 PM
97MaxGurl's Avatar
Chick specializing in rounding up 100+ Maximas
I decided to swap my Stillen intake with a friend who had the generic cone-intake because I was having my CAI pipe custom painted. Two weeks later I noticed a black residue on the abs plastic ring on tip of the cone filter. Appearently the cone was rubbing against the enginebay, the friction stripped a bit of the black paint to bare metal. Little did I know that the cone intake doesn't come with a bracket, that's just plain ghetto. I never had this problem with the Stillen intake b/c I had the bracket to hold the K&N filter in place.
How do you 'pop-charger' guys go without the bracket piece?
Old Sep 3, 2002 | 01:53 PM
costcowholesale's Avatar
put the bottom part of the stock airbox back on & let the cone filter sit on it
Old Sep 3, 2002 | 08:34 PM
MaximaPower's Avatar
y not make ur own bracket?
that's what i did with the monster flow filter i got from the cattman GD that u did awhile back..it didn't come with a bracket so, i went to home depot and got one of those metal things that are used to connect two pieces of wood together...u'll find it near the stuff for fences
Old Sep 3, 2002 | 08:49 PM
Bad97MaxSE's Avatar
mine works fine with out a bracket .
Old Sep 4, 2002 | 12:31 AM
mingo's Avatar
i built my own bracket
Old Sep 4, 2002 | 03:49 AM
redmaxpa007's Avatar
i SeE what you did therE
i put a piece of foam rubber where on the spot it was rubbing. the piece was big enough to put a screw through (the hole for one of the screws on the bottom of the OEM intake box)it looked a little silly, but it worked till i got a bracket
Old Sep 4, 2002 | 05:15 AM
Mishmosh's Avatar
Me too. ...used backstrap from Home Depot and an elbow piece to attach it to one of the bolts holding in the adapter-to-maf. Running a hybrid setup but should be no different.
Old Sep 4, 2002 | 06:33 AM
slickwillie's Avatar
I used a bungee cord, But its red so it matches my engine color scheme
Old Sep 4, 2002 | 06:35 AM
97MaxGurl's Avatar
tks guys..
...this issue is best resolved by installing my CAI altogether.. after 5 months, must speed up the process
Old Sep 4, 2002 | 06:42 AM
Re: tks guys..
Originally posted by 97MaxGurl
after 5 months,
WHOA.. stop lolly gaging around..
Old Oct 11, 2002 | 11:58 AM
JsL's Avatar
JsL
So if I get a Stillen pop and a franken mid pipe, I dont need a bracket right? I can just leave the bottom portion of the airbox and have the stillen sit on it right?
Old Oct 11, 2002 | 12:36 PM
Mishmosh's Avatar
If i were you, i'd make your own bracket. Why would you want your filter banging up against the stock box all the time?
Old Oct 11, 2002 | 12:38 PM
Blaxxxima's Avatar
!OG SNES OG!
Geez... can't you order the piece from Stillen?
Why leave that ugly a$$ airbox bottom in there? ALTHOUGH, the frankencar/stillen isn't as snug as it could be, simply because the mounting bracket forces a small bend in the straight line the frankencar should take, and causes the rubber mounting on the throttle body to sit somewhat crooked.
But at least my Stillen POP is still held in place.
Mike
Old Oct 11, 2002 | 02:12 PM
JsL's Avatar
JsL
The stock air box with its air scoop, although inefficient, will bring some cold air to the filter. I think its better than just having the filter in the engine bay alone w/o the bottom portion of the box. I was also planning to use some cushions where the filter rest on the box, but wasn't sure at first if that works.
Old Oct 11, 2002 | 02:17 PM
ericdwong's Avatar
I bent 2 brackets as well. However, I need to rebend mine, my filter is banging the car and I can hear it if I step on the clutch aggressively after heavy acceleation.
Old Oct 11, 2002 | 02:20 PM
when DON"T you do this?
Apr 16, 2020 05:15 AM
Calabar
Oct 5, 2015 09:57 PM
followthadollar
Sep 22, 2015 11:53 PM
jcvgn
Sep 13, 2015 11:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
