How to redline an auto?
Old Sep 18, 2002 | 12:38 PM
DaveGrun's Avatar
I have an auto, and i wanted to know if there was something you can adjust to make the auto shift at redline, instead of at 6K, without a tranny mod.
Old Sep 18, 2002 | 12:42 PM
Str8ridin's Avatar
Re: How to redline an auto?
Manually shift I guess. Never tried that though.
I know for sure if you take it out of overdrive, you can redline 3rd gear. Pretty fun stuff...
Old Sep 18, 2002 | 12:45 PM
MaximusMax's Avatar
Yes, you can...I do it on occasions. The only hard part is that you have to shift at about 300rpm before redline...it takes a second for the car to switch gears.
Old Sep 18, 2002 | 12:48 PM
voltman's Avatar
Leave it in park or neutral and floor it to your heart's content.
Old Sep 18, 2002 | 12:51 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Old Sep 18, 2002 | 01:42 PM
korupter's Avatar
that be bad for the auto tranny yo
Old Sep 18, 2002 | 02:08 PM
95emeraldgxe's Avatar
manually shifting kills your tranny - but if u want to - just bring it all the way down to 1 then to 2, etc
Old Sep 18, 2002 | 02:11 PM
MaximusMax's Avatar
That's why I only do it on occasions. I wanted to figure out when exactly to shift to get it to redline. In a way, it was more of an experiment, but yes, I do know that it can kill the tranny.
Old Sep 18, 2002 | 02:18 PM
costcowholesale's Avatar
? I think only the 2-1 downshift is bad in auto.
another solution is get a red marker & extend the redline from 6700rpm to 6000rpm then u can redline it everytime & leave it in D !
Old Sep 18, 2002 | 02:19 PM
soundmike's Avatar
Very sound, Mike
I'm still not quite sure why this would be the case. I figured, since the transmission actually thinks before actually upshifting even when you told it to do so a second earlier then there's not much of a difference than just leaving the shifter at 3 or D. Either way, the ECU will dictate the actual shift.
Now as far as redlining it, keeping it in 3 will make it redline all preceeding gears.
Old Sep 18, 2002 | 03:15 PM
Greg's2kGLE's Avatar
How does manually shifting kill your tranny? All you are doing is telling the computer when to shift.
Old Sep 18, 2002 | 03:18 PM
gtr_rider's Avatar
192.168.1.1
its not, its when you tell it to downshift when it doesnt want to ..
Old Sep 18, 2002 | 03:27 PM
Wicked's Avatar
ok to redline you have to put it in first. then wait till the neddle gets to exactly 6ks then shift to 2nd. it takes a second for it to shift, so it will shift at redline if you do it at 6k.
Old Sep 18, 2002 | 03:39 PM
soundmike's Avatar
Very sound, Mike
Hmm, downshifting to 3rd when cruising at highway speeds (e.g. 70mph) by stepping on the gas more is not much different than sliding the shifter to 3. I've never tried going down to 2 but i'm assuming that won't happen otherwise the tranny would do it already just by stepping on it.
Old Sep 18, 2002 | 04:00 PM
Mmmaxx's Avatar
If you were to do it, I do it on the occasional rice run, shift into 1st (way bottom), power brake to about 2000 rpms...floor it...ride it till about 4,000 rpm shift up to drive (D) hammer till about 5k, shift down to 2nd and finish. Defintly kills tranny quickly though. Im never going to do it again
Old Sep 18, 2002 | 04:04 PM
gtr_rider's Avatar
192.168.1.1
well... putting it in "3" which there is no such thing from what I have in my max is not the same as flooring it into 3rd. If i was to go ahead and floor it at 45MPH so that it downshifts to 2nd from 3rd or 4th is not the same as slamming the tranny to 2nd yourself. When you your flooring it the tranny has full control and eases the downshifts, you pulling the shifter really forces it down..
Old Sep 18, 2002 | 04:14 PM
jkotel's Avatar
so starting at 1 and shifting up isn't bad at all for your tranny?
Old Sep 18, 2002 | 05:50 PM
mzmtg's Avatar
Minister of Silly Walks
No.
And the best gear to redline is 3rd:
Old Sep 18, 2002 | 06:02 PM
soundmike's Avatar
Very sound, Mike
I have a 2k2 so i have 3.
I understand what you're trying to say however. Though i'm still curious, how exactly does the tranny "ease" the downshift? Isn't a downshift a downshift?
Old Sep 18, 2002 | 06:16 PM
gtr_rider's Avatar
192.168.1.1
ease as in, it knows its going to happen so it disengages the 'clutch', what your doing is just popping it down.. For example, if you are driving your 5spd, and you decided let me just drop the gear without clutching out, what would happen?
Old Sep 18, 2002 | 08:02 PM
soundmike's Avatar
Very sound, Mike
I'm familar with how it works on a manual tranny equipped vehicle, though with proper timing/matching one can forego the clutch w/o much grinding.
Anyway, i'm just under the impression that if the auto tranny "thinks" before following a command to upshift that it would tend to follow the same process when downshifting. And if this were to be the case then it should be able to "ease" into it.
user 11122324
42
Jul 18, 2022 03:35 PM
AaronL
Aug 8, 2020 10:31 AM
Maximeltman
Sep 28, 2015 07:19 PM
dshinn
Sep 26, 2015 08:07 PM
