I finally get why people say don't buy cheap bulbs...
Old Sep 21, 2002 | 02:55 PM
Jepht20's Avatar
Custom User Title...
i've been using Nokya whatever's for a couple of months, without upgrading the harnesses because i'm smart, or lazy...anyways, last night i noticed my lights looked like they weren't even on as i was driving to burger king with some friends...so when i got there, one of my headlights was out cuz the wire comes loose every now n then. so i fix that. when it came back on, the other one looked really dim and yellow. so i took it out to check it, boom...it explodes. luckily i had just bought a pair of phillips blue visions the week before, so i got those from my trunk and replaced other ones.
cliff notes: don't buy cheap bulbs for $20 on ebay, especially if you're not gonna upgrade harnesses.
Old Sep 21, 2002 | 03:01 PM
Maxima06071
Damn that's crazy my OEM head lights burnt out so I just went to Wal-Mart and got some GE Hyper Blue Plasma, well they didn't explode but they didn't last more that 4months. When you sadi they exploded did you literly mean the glass shattered?
Old Sep 21, 2002 | 09:06 PM
MaximaPower's Avatar
uhhhh...were ur bulbs higher wattage than normal? u need to upgrade the harness if u go with higher wattage no matter how expensive the bulb is.
Old Sep 21, 2002 | 10:44 PM
NYCe MaXiMa's Avatar
you're right
but, i haven't heard of higher wattage bulbs actually exploding because of improper harness connected to them..
what usually happens in these cases is the socket melts.. i think.
i have upgraded wire harness, or should i say.. had.
i had the APC one and after a year and change use they weren't functioning well
Old Sep 22, 2002 | 12:22 AM
Jepht20's Avatar
yeah, i noticed it was dim so when i unscrewed it and took it out, whammo kaboom!, it exploded...i noticed today the top half of it is in the headlight housing itself...i should probably take care of that sometime. it was really weird to say the least.
Old Sep 22, 2002 | 06:48 AM
NickStam's Avatar
your not supposed to touch the bulbs with your finger either.
Old Sep 22, 2002 | 07:16 AM
karguy's Avatar
I bought 3 sets of Nokya bulbs on eBay, in 5 months 4 of the bulbs had burned out. Unbeleivable junk!
Old Sep 22, 2002 | 07:28 AM
gtr_rider's Avatar
192.168.1.1
If you've been running the lights, I dont think you should be pulling them out of the housing right after or while they're in use. It will most definately result in a lose of the bulb or one of its filaments.
Old Sep 22, 2002 | 10:34 AM
Jepht20's Avatar
don't worry i didn't.
Old Sep 22, 2002 | 04:43 PM
Capitone's Avatar
A bulb will usually burst if it has been handled in this manner....touching the bulb. Believe it or not, but the oil which can be found on your fingers will create a "hot spot" on headlight bulbs and most will usually burts or blow prematurely. As a rule of thumb you should always wipe new bulbs down with rubb'n alchohol and a napkin
Cotozic
Jun 28, 2017 08:01 PM
doctorpullit
Aug 20, 2015 05:15 PM
maxinout93
Aug 16, 2015 07:25 PM
MikesChevelle
Aug 6, 2015 11:36 AM
