Gates K060705 Does not fit with 3.125
Old Oct 11, 2002 | 11:23 AM
Bandit's Avatar
I found several pages that says this is the right belt, from reputabvle ppl like Kev, etc.
Anyways, my mechanic says the belt is too long and he thinks it's going to squeal like mad. I told him I was certain it was the right belt, but he doesn't think so.
Anyone got any ideas, or can tell me for sure that it's right.
Thanks, PS it's going on a V1
Old Oct 11, 2002 | 11:25 AM
Sprint's Avatar
time to sue kev
Old Oct 11, 2002 | 11:35 AM
Chunger's Avatar
My other car is a Hybrid
Re: Gates K060705 Does not fit with 3.125
That is the belt # for a V2 kit
Old Oct 11, 2002 | 11:36 AM
Bandit's Avatar
Re: Re: Gates K060705 Does not fit with 3.125
Damnso what's the v1 number?
Old Oct 11, 2002 | 11:39 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Works for MardiGrasMax, JAY25, iansw, etc. (all V1). Are you sure the mechanic didn't miss looping around a pulley?
Old Oct 11, 2002 | 11:40 AM
Bandit's Avatar
Thanks Kev, the mechanic said the pulley he took off was seems longer then the new gates one???
Ok, how tight is this belt supposed to be, he says there's 1/4' to 1/2" of tension (whatever that means).
Thanks for the replies!
This is second gen V1 btw
Old Oct 11, 2002 | 11:48 AM
JAY25's Avatar
Matt had the 3.125 pulley and it worked just fine for him. Tighten the belt with the adjuster and then tighten the tensioner pulley the belt will sinch down some more. If not then PM Mardigrasmax and ask him if you dont believe us.
Old Oct 11, 2002 | 11:49 AM
Bandit's Avatar
I told my mechanic to give it a shot, he thinks it may work he's just not accustomed to it being that loose, he said maybe it's that looses to protecth th sc's bearings. Anyways, he says he can get a 1" shorter belt and do it with that, but he'd have to start all over and charge me for that, doh.
I told him to try it with the gates belt i gave him, he's gonna fire ti up and see.
Old Oct 11, 2002 | 11:50 AM
Bandit's Avatar
Where/what is the adjuster?
Old Oct 11, 2002 | 11:52 AM
delio's Avatar
For a 3.125 try the 695 length...
Old Oct 11, 2002 | 11:53 AM
Bandit's Avatar
That's what he's going to try if this doesn't work, I'm just ****ed cause he has to then start all over.
delio's Avatar
Matt did not use the 705 for his pulley, 695 is where it's at.
Old Oct 11, 2002 | 11:55 AM
Bandit's Avatar
Damn I wish I could of got these answers initially, costly mistake.
To those who think it should work, are you positive this works on a V1?
Old Oct 11, 2002 | 11:57 AM
delio's Avatar
considering how many times I have done it, take my word for it... go get the 695 belt and be done with it.
705 may fit, but will be too loose, prolly not allow for enough tension if not slide off all together
Old Oct 11, 2002 | 12:01 PM
Bandit's Avatar
695 is going on now, now I got a new 705 for sale, anyone want?
He says he thinks he can do it in an hour now.
Old Oct 11, 2002 | 12:04 PM
Y2KevSE's Avatar
Woah! 695 is short. That wouldn't even go on the 2.87" on the V2's.
How long is Cummy's thingy?
Old Oct 11, 2002 | 12:12 PM
JAY25's Avatar
the belt adjuster is the thing that adjusts the tension on the belt. If Delio says that Matt had a 695 then go w/what he says. Just PM him if anything.
Old Oct 11, 2002 | 12:13 PM
Bandit's Avatar
I guess v1 is diff cause my mechanic thinks 695 will fit very nicely.
Old Oct 11, 2002 | 12:21 PM
Cumalot's Avatar
You're talking to me?
I don't know what size the belt is. You have to ask Lynn Tong, that was his SC. The belt was on there already along with the 3.125 pulley. It's a Goodyear Gatorbelt though, not a Gates. Suprisingly, the belt is holding up pretty good, no tear or anything.
Btw, I think my boost problem is fixed. I adjusted the BOV which seem to be the culprit. I will know for sure if my boost problem is fix next week. I'm heading to the track(finally stop raining!), so I will know for sure once and for all. Oh, I will remember to do the multi-task.
Old Oct 11, 2002 | 12:31 PM
Bandit's Avatar
My mechanic is putting in the goodyear gatorback as well, he thinks it's a REAL good belt.
Anyways, cumalot what was wrnog with your BOV, open too much or too closed. What BOV conditions would cause boost loss?
delio's Avatar
I think the 695 is actually the stock size for the SC...
Old Oct 11, 2002 | 12:34 PM
Bandit's Avatar
Ther wouldn't I need even a smaller one for the 3.125?
Old Oct 11, 2002 | 12:37 PM
Y2KevSE's Avatar
Are you serious?
Yes, I was talking to you Cummy. If you didn't change the belt, then you have the K070605 Gates equivalent belt because Lynn asked me.
Old Oct 11, 2002 | 12:42 PM
delio's Avatar
No... 695 will do it.
Old Oct 11, 2002 | 12:48 PM
Bandit's Avatar
good it's going in.
Old Oct 11, 2002 | 12:49 PM
delio's Avatar
good it's going in.
Good to see your taking my advice
Old Oct 11, 2002 | 01:33 PM
Bandit's Avatar
Wow my mechanic got the new belt and everything ready to go in 35 minutes, so he's only charging me an additional $25 cause he had to do it again.
Thanks for all the advice guys, and thanks for the timely responses.
Old Oct 11, 2002 | 03:17 PM
Chebosto's Avatar
RIceD OuT moDErAtor
you answered your own complaint:
he THINKS.
did he even try it?
Old Oct 11, 2002 | 03:19 PM
Bandit's Avatar
Ok I got the car, I instantly noticed that I have boost at like 2000 RPM liek I used to have at 3000-3500 which is very nice.
After a little while I put it down, I was only able to manage about 7.5 PSI on the guage, before I had been hitting just about 6 in the middle of the hot day.
My BOV (greddy) was insanely loud, so I tightened it down to about 5-6 threads and just hit about 9 PSI.
If I recall V1's tend to boost about 1 LB less then the same V2/pulley combo. That would mane I'm hitting about 10 on a V2. I'll probably be able to manage 10 when it gets colder.
All in all though it feels faster from 4000-5500 but not too much faster after 5500, I guess I need that MEVI to get this thing to breathe.
Autometer guage seems to be in just about the same place when I'm WOT that it was before the install, and the boost guage seems to shake a little more then it did with stock pulley.
Old Oct 11, 2002 | 03:30 PM
Y2KevSE's Avatar
Congrats!
Old Oct 11, 2002 | 05:16 PM
Cumalot's Avatar
I got the same BOV as you do, the Greddy. It was open up too much I think. I adjusted down to about 5 threads left with the hex nut on. Much better response now.
Old Oct 11, 2002 | 05:23 PM
JAY25's Avatar
Glad to see you got the other belt, the 605. Michael when are you going to get that ME VI? I am thinking of ordering one in about 90 days.
Old Oct 11, 2002 | 07:31 PM
Cumalot's Avatar
Since I bought new wheels, the MEVI will have to wait. I can't get anything more for awhile.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
