Hood struts replacement procedure?
Old Oct 11, 2002 | 12:09 PM
1MAX2NV's Avatar
Is there anyway to dislodge the ball joint part? It's hard to get a wrench in there without scraping the paint off the hood.
Old Oct 11, 2002 | 12:11 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Don't worry, it's only a few points when they judge you.
Old Oct 11, 2002 | 12:19 PM
1MAX2NV's Avatar
aarrggghh...I guess I could bust out my dremel out and cut a slit. Then just jam a screwdriver in there and pry the sucker open.
Old Oct 11, 2002 | 12:47 PM
redmaxpa007's Avatar
i SeE what you did therE
cut your hood off and replece.. simple..
Old Oct 11, 2002 | 12:54 PM
Jepht20's Avatar
Custom User Title...
took forever for brendan and i to figure it out. we used a flat headed screw driver to pry that piece of plastic out...it's the thin black plastic piece that holds the struts snug to the ball joint. once you price that out, they come right off, takes about one minute. hope that helps....
Old Oct 11, 2002 | 01:07 PM
97MaxGurl's Avatar
Chick specializing in rounding up 100+ Maximas
too bad you're not driving her up..
Otherwise I can help strip the car..I mean.. replace the hoodstrut
Old Oct 11, 2002 | 02:14 PM
Slowpoke's Avatar
You just need to work the wrench at an angle. It's a bit of a pain but not that bad. I'm pretty sure I didn't scrape any paint off.
Old Oct 11, 2002 | 07:29 PM
1MAX2NV's Avatar
Took 20 mins to replace both sides. I was careful with the wrench and everything turned out okay.
Old Oct 11, 2002 | 08:53 PM
ny96max's Avatar
Tony with all the mods done to your car i would think changing hood struts would be a breeze for you
dont worry though i felt a lil discouraged when i had to change my wiper blades
Ant
Maxima_Joe
Nov 25, 2015 08:19 AM
95Maxi
35
Sep 2, 2015 10:37 AM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 12, 2015 01:54 AM
laparka66
Aug 6, 2015 09:36 AM
