For anyone who cares (no turbo info inside) B&M Tranny Cooler in colder weather info
Old Oct 15, 2002 | 09:58 AM
deezo's Avatar
This morning it was 28 degrees in my town of Franklin, MA so I figured Bill and a lot of you auto guys would be interested in knowing how the tranny cooler reacts to freezing temperatures and not allowing overcooling.
I have the:
130-70264 SuperCooler 24,000 GVW (11'' x 6'' x 1.5'') - $49.99
I intalled it this summer being that it was so hot and I didn't want to overheat my tranny no more than I have in the past with dragging and tons of highway running.
Anyways, I let the car warm up for about a minute and started on my way. The onramp to the major highway is about 2 blocks from my home so by the time I entered the ramp, I still wasn't at normal operating temperature. The car shifted as it would when your autotranny fluids are still cold (just a small jerk when shifting). After normal operating temps were a acheived, the tranny shifted a smooth as silk. This means that the bypass valve within the Supercooler is doing its job even though my particular cooler is designed for a load of 24,000 GVW.
My supercooler is positioned in front of the radiator, right behind my valance opening (behind my aftermarket fogs) to get the most unrestricted airflow.
In the past, coolers have caused problems with shifting in cold weather and I've heard of drivers blocking the cooler with cardboard to allow the heat to build up so the tranny would shift smoothly. The problem is gone with the B&M Supercoolers. Hope this helps with anyone concerned about using a cooler in cold weather.
Old Oct 15, 2002 | 10:12 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Great feedback, deez......
Old Oct 15, 2002 | 10:19 AM
Eric L.'s Avatar
I have the B&M cooler too and I've never worried about overcooling. I run Redline D4 ATF and I think that stuff flows well no matter what the temperature.
ereet's Avatar
Re: For anyone who cares (no turbo info inside) B&M Tranny Cooler in colder weather info
How do you think it'd affect the car in say, one of our canadian blizzards? Sounds like it'd be probable to still be safe.
Old Oct 15, 2002 | 10:24 AM
deezo's Avatar
Re: Re: For anyone who cares (no turbo info inside) B&M Tranny Cooler in colder weather info
You guys do see more over the drop-dead cold weather than we will see in the NE but I'm confident you will be fine. It's not neccessary to get the one I bought though. Jime is running the say cooler and he hasn't complained about it.
Old Oct 15, 2002 | 10:27 AM
Bags's Avatar
VG Ridah's Biatch Hoe
thanks for the info deezo
Old Oct 15, 2002 | 10:29 AM
bill99gxe's Avatar
As long as synthetic ATF is used, it is less likely to be an issue. Also, taping or placing a rubber band around some cardboard in front of the cooler will help make the cooler "inefficient" and won't overcool the fluid......
Old Oct 15, 2002 | 02:06 PM
Blu's Avatar
Blu
the tits
good info I have that same cooler sitting in my living room as we speak. Guess I need to get it installed
Old Oct 15, 2002 | 02:31 PM
iwannabmw's Avatar
When did you move to Franklin?
Old Oct 15, 2002 | 05:04 PM
deezo's Avatar
2 Mondays ago and I'm loving it.
Old Oct 15, 2002 | 06:49 PM
Stillnmax's Avatar
well assuming people arent racing in the middle of winter and beating on the auto trans, placing a cardboard infront of your cooler wont really make that much of a difference.... thats just my assesment of the situation.....
anyone else care to comment ?
Old Oct 16, 2002 | 04:32 AM
redmaxpa007's Avatar
i SeE what you did therE
i have the shiny one your returned...the racing one..
Old Oct 16, 2002 | 05:20 AM
Lime's Avatar
good deal! My car likes the garage! I don't know what model I have...it looks exactly like yours and it's big huh huh. It's B&M.
Old Oct 16, 2002 | 05:53 AM
Stephen Max's Avatar
Some auto transmissions have an internal thermostat that keeps transmission fluid from circulating to an external cooler (such as the one in the radiator) until the transmission warms up. Maxima transmissions don't have one?
Old Oct 16, 2002 | 05:59 AM
bill99gxe's Avatar
The Maxima auto transmission is not one of them.
B&M's SuperCooler series of tranny coolers is the only major tranny cooler maker I'm aware of that includes a viscosity driven "valve" that prevents cold fluid from flowing across the entire plate surface of the cooler.
Old Oct 16, 2002 | 06:12 AM
deezo's Avatar
I remember you told me you had that one but did you say you spent money on all of the hardware to contect it. I have everything you need to set it up.
Old Oct 16, 2002 | 06:19 AM
bill99gxe's Avatar
Why chrome instead of pink?
Old Oct 16, 2002 | 06:20 AM
shut it..
deezo--><---jeff
Old Oct 16, 2002 | 06:27 AM
no one asked you.. go away...
Old Oct 16, 2002 | 06:28 AM
srbarnes4ever's Avatar
Lots a luv in da room today!
Old Oct 16, 2002 | 06:31 AM
no one asked you either.. go away!!
bill99gxe's Avatar
I thought I asked you.
Is that a sore spot or something you don't want to talk about? Are your friends making so much fun of you that chrome re-establishes your manhood?
Old Oct 16, 2002 | 06:37 AM
you are only a moderator.. you don't count
NNOOOOO
it is a sore spot when you realize that it is going to cost more in fittings to connect the cooler than the actual cost of the cooler.
i ended up getting fittings at home depot and had to keep the "racing car fittings" as a memento to how much $$ i actually spent..
Old Oct 16, 2002 | 06:40 AM
DanNY's Avatar
Ad·min·is·tra·tor
chrome (damn too early to get the right words out) can reflect the color(s) from the pink lights
Old Oct 16, 2002 | 06:46 AM
Originally posted by DanNY
cold can reflect the color(s) from the pink lights
boy oh boy.. everyone has jokes today...
i would do this to you..
DanNY--><--ME
but it would turn into this .. cause you would like it..
DanNY--><--me
Old Oct 16, 2002 | 06:51 AM
DanNY's Avatar
Ad·min·is·tra·tor
DanNY--><--ME
DanNY--><--me
heehee..hey you're powered by pinky not me!
Old Oct 16, 2002 | 06:52 AM
[QUOTE]Originally posted by redmaxpa007
[B]
Bad, bad, boy!!!
Old Oct 16, 2002 | 06:54 AM
bill99gxe's Avatar
DanNY--><--me
Great, first a pink car now
Old Oct 16, 2002 | 07:06 AM
notice i am not liking it.. DanNY is..
Old Oct 16, 2002 | 07:17 AM
DanNY's Avatar
Ad·min·is·tra·tor
Old Oct 16, 2002 | 07:23 AM
Bags's Avatar
yall gonna make me act a fool... up in here
Old Oct 16, 2002 | 07:26 AM
deezo's Avatar
Why chrome instead of pink? :confused
Damn! Jeff is losing his mind. I was saying that I had the fitting and that if you needed them, I would send them to you.
Old Oct 16, 2002 | 09:19 AM
SuDZ's Avatar
Hehe someone is defensive today.
SuDZ
Old Oct 16, 2002 | 09:21 AM
SuDZ
what did you say!!
Old Oct 16, 2002 | 09:33 AM
Bags's Avatar
I would say jeff should have used his phone a friend a long time ago..
Old Oct 16, 2002 | 10:30 AM
acMAX's Avatar
SuDZ
that's cuz for some reason or another he's being called "gay" (ghey, gey, or ghay) in about 5 different threads.
don't worry redmaxpa.....i don't think you're gay, gey, or even ghey for that matter.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
AaronL
Aug 8, 2020 10:31 AM
TKHanson
Nov 24, 2018 01:39 AM
bernyp
Oct 2, 2015 10:10 AM
