difference between wet and dry nitrous kit?
Old Oct 22, 2002 | 06:25 PM
theMax's Avatar
I thought I knew the difference but saw the NX wet kit (link below) with one fogger nozzle? Can someone tell me the difference? Nitrous pressure?
http://www.nitrousexpress.com/produc...oc=101&dealer=
Old Oct 22, 2002 | 06:36 PM
Sprint's Avatar
wet is safer in a direct port setup..
dry is easier to tune and optimum for 25 - 100 shot..
wet distributes nitrous evenly to each cylinder and doesn't use the factory injectors
dry doesn't distribute as evenly and may cause certain cyclinders to run lean.. dry also uses factory injectors..
search for the rest
Old Oct 22, 2002 | 06:46 PM
Jime's Avatar
Re: difference between wet and dry nitrous kit?
I have installed and run both on the same car within the last 6 months here is my opinion.
http://forums.maxima.org/showthread.php?threadid=150807
theMax's Avatar
Go figure search came up with something this time... (when I used "wet")
Q. What is the difference between a wet and a dry system?
A. A "Wet" system introduces a homogenous mixture of nitrous and atomized fuel into the incoming air stream, thus providing a perfect air/fuel ratio for each.
thanks!
Old Oct 22, 2002 | 07:18 PM
theMax's Avatar
Re: Re: difference between wet and dry nitrous kit?
actually it was that thread what got me asking some questions! thanks
James92SE
142
Jan 2, 2024 09:23 AM
doctorpullit
Apr 23, 2017 05:35 AM
doctorpullit
Dec 12, 2015 09:39 AM
fastcarny
Oct 12, 2015 07:06 AM
