Engine swap guide??
Old Nov 5, 2002 | 04:43 AM
Cheuk in Seoul's Avatar
Engine swap guide??
I work with a couple of tuning shops in Korea. The question I have is which Maxima engines are interchangable within the engine bay. I guess this includes the TT 300ZX engines also.
Samsung Motors makes a copy of ?4th generation Maxima (SM5) but supplies only 1.8L / 2.0L 4 cylinders and a 2.5L V6... I believe the V6 is nearly identical to the 3.0L V6 available for the Maxima. There are several customers who are interested in a complete engine / ECU swap to the 3.0L engine. How interchangable are the engines between the Maxima generations? Assume that one is not swapping the transmission.
My idea is to get the bell housing gaskets for these Maxima engines and compair them to the gaskets on the Samsung Motors' cars to confirm that a Maxima engine will swap into the tranny / engine bay of the Samsungs. What do you guys think??
Old Nov 5, 2002 | 08:01 AM
1MAX2NV's Avatar
It's possible if you get a whole front clip of a US maxima. This way, you will have the tranny, motor, all the harness and the ECU. I would try a VQ30DE (1995-1999) first since there are more readily available than the other maxima engines.
Old Nov 5, 2002 | 08:02 AM
Black VQ's Avatar
Well..
There isn't really anything you can just 'swap' into our Maximas. We just make do with what we have.
There's no point in replacing our VQ30DEs for SR20DEs.
The VG30DETT from the 300ZX is rwd, so forget about that immediately.
The VQ25DE is smaller than our VQ30DE, so again, no point.
That's why we've never made an engine swap guide for our Maximas. Even on the swaps that might be possible, they won't do you any good!
However, in Korea, you guys have a 2.5L V6, which should be the VQ25DE. If so, you should be able to replace it with a VQ30DE, since I'm betting there's few differences on the outside of the engine. The only thing I would worry about is the tranny. You said you weren't going to change it, though the gear ratios might be different, because of the different engine outputs.
Old Nov 5, 2002 | 11:24 PM
VQ30DE... sounds good.
We will probably get our engines from Japan... the land of the cheap @ss used engines.
Old Nov 5, 2002 | 11:46 PM
carnal_c30's Avatar
Former Sponsor
the other thing to do is to get a Sunny GTiR motor... the 2.0L you have over there is the SR20DE, probably you know that the SR20DET is capable of pushing 400-500 hp fully built
Old Nov 6, 2002 | 09:45 PM
The customers are looking for a cheap stealth look... the Police can be a PITA.
There are already a handful of the SR20 turbo conversions running around... some making in the 400-500 hp range. But that build up and engine swap is far from cheap. Used engines are cheap from Japan but high performance tuning parts are overpriced.
Old Nov 6, 2002 | 10:28 PM
Larrio's Avatar
The Definitive AE Master
the VQ25DE has been known to put out much better times on the track and performance wise than the VQ30DE. This is from turbo/Supercharged experience from VQ25DE's in taiwan.
Old Nov 7, 2002 | 02:10 AM
lp's Avatar
lp
Is this comparing the variable intake VQ25DE with the non-VI VQ30DE or comparing VI'ed versions of both motors?
Old Nov 7, 2002 | 02:54 AM
pezking4's Avatar
The VQ25DE is used in the Cefiro, which is the Jap version of the Maxima of course, and uses a V6.
The other 2.5L engines are the RB25DE in the Skyline, and the QR25DE in the new Sentra SE-R
Old Nov 7, 2002 | 07:10 AM
Larrio's Avatar
both VI'ed
Old Nov 7, 2002 | 06:30 PM
carnal_c30's Avatar
Former Sponsor
hmmm are you sure they are VId? in Taiwan
we get the VQ20DE, the VQ30DE, and the new VQ35DE
there are superchargers available for the 2.0 and the 3.0L, havent seen turbos except on the Japanese VQ25DETs and the VQ30DET
are ya gona be back this xmas Larry??
Old Nov 7, 2002 | 06:54 PM
Larrio's Avatar
some friends of mine were trying to throw the VI from the 3.0 onto the 2.0... need to check back with them on that.
i dunno if i'm heading back for x-mas.. but if I do i'll get to see the vq25det and possibly vi'ed vq20.... hehe
Old Nov 7, 2002 | 08:02 PM
Interesting. Any websites or further info. My concern with turbo or supercharging the VQ25DE is the need for lower compression pistons and fuel/ ignition control.... Korean premium is 94 RON or 89 AKI octane.
Old Nov 7, 2002 | 09:03 PM
Larrio's Avatar
unfortunately no sites that I can offer cause it was kind of just friends experimenting at first with the engines. You should be fine with the stock engine depending on how much boost your running. Alot of VQ30DE-K engines are supercharged with no changed internals
Old Nov 7, 2002 | 11:35 PM
carnal_c30's Avatar
Former Sponsor
yup the VQ is a pretty solid engine for being a high revving light weight aluminium block engine
Running above 9 pounds of boost, I'd recommend to start building your internals
Old Nov 7, 2002 | 11:49 PM
Larrio's Avatar
you running boost anytime soon my friend?
Old Nov 8, 2002 | 12:39 AM
carnal_c30's Avatar
Former Sponsor
sooner than later!! just debating over which method to go!! plus i gotta get back from Taiwan first!
Old Nov 8, 2002 | 09:41 AM
Larrio's Avatar
your in taiwan again?! lol...
go turbo instead... i wanna see 300plus whp
Old Nov 9, 2002 | 02:01 AM
carnal_c30's Avatar
Former Sponsor
thats the plan! I'll be in Taiwan Nov 24th
Old Nov 10, 2002 | 12:31 AM
Doesn't sound like anything written in stone. So is it mostly hearsay. I am looking for hard numbers... dyno runs, ECU modifications, injector upgrades, a/f ratios... the works.
The only kit I see for superchargers is Stillen's but it is way overpriced and made to fit the VQ30's...
Old Nov 10, 2002 | 12:47 AM
carnal_c30's Avatar
Former Sponsor
do a searc for turbo kit- you'll find Nigels (turbo97SE) dyno of 372hp at 11.5 lbs of boost stock internals
Old Nov 10, 2002 | 10:31 AM
turbo97SE's Avatar
If you are there week of the 18th, I'll be able to meet you too!
Old Nov 11, 2002 | 01:53 AM
carnal_c30's Avatar
Former Sponsor
damn I duno my flight arrives Tuesday morning November 26th 6:10 am Taiwan time, I'll be there until Xmas eve so maybe you'll find some time!
Old Nov 11, 2002 | 09:22 AM
Larrio's Avatar
i wanna go...
no money for ticket
derekinthez
Nov 13, 2022 04:00 PM
fastcarny
Oct 6, 2015 10:42 AM
kjlouis
Oct 3, 2015 05:29 AM
I<3 A32's
Sep 10, 2015 11:07 AM
