A couple lights on dash out. . .
Old Sep 8, 2000 | 10:54 PM
GarthG's Avatar
On my 95 SE, the light behind my Hazard lights and the light behind my A/C dial are both out. Anyone know the reason for this and how I may be able to change them? It would be nice to have them working again just because It looks a little dark on that side of the dash at night.
Old Sep 9, 2000 | 05:53 AM
Che's Avatar
Che
man the light behind my climate controls
have been out for years.....if you find out how to change the bulbs, let me know....as a matter of fact, my blower only works on 4, none of the other speeds does a thing....i wonder what that is?
Old Sep 9, 2000 | 07:41 AM
easy to change bulbs....
you just take out the screws and pull out the dash.(really easy and straight forward) Then you pull out your guage cluster....kinda have to jimmy it out a bit. Unplug the sensors from the back and all the bulbs are labeled on the back. Just have to go and buy the itty-bitty bulbs like your corner lights by your turn signal. If you run into any problems let me know. The bulbs just twist out like headlight bulbs......later
Old Sep 9, 2000 | 08:13 AM
Che's Avatar
Che
you have to pop off the trim panel in center console first, right?
nm
Old Sep 9, 2000 | 08:28 AM
mingo's Avatar
yeah
two screws on the top.. i think.. or at least it is on the 5th gen and ludes.. and pry it off bottom first.. while ur changing the bulbs, might as well get hyper whites.. make that real bright and white.....
not sure dun take my word for it. u mess up then uh ohhh aint' my fault
Old Sep 9, 2000 | 09:47 AM
Ants97SE's Avatar
Che: As far as your blower goes,
try taking out the A/C unit and check the connector behind the switch, if it is corroded, best bet is to get a new switch. That's what was wrong in my Altima.
Old Sep 9, 2000 | 11:51 AM
GarthG's Avatar
Re: easy to change bulbs....
I pulled the dash, and got the wiring harness off the back of the hazard switch. The problem I am having is getting the relay or whatever it is that the harness is attached to. I tried everything to get it out, and no matter how hard I press the side button, it won't budge. I don't want to break it so I am hesitant of yanking really hard on it. Any suggestions?
Also, There isn't any bulds thatI can see behind the switch to turn on the A/C. It doesn't look like the metal circular thing below the wiring harness can be removed. Am I just not seeing something?
Old Sep 10, 2000 | 11:17 AM
Che's Avatar
Che
thanks ants, i will check it out this week
and let you know how it goes.
Old Sep 10, 2000 | 01:06 PM
Ants97SE's Avatar
Cool, hope you fix it... n/m
n/m
King_Ten_Ahead
Sep 30, 2015 04:27 PM
homeyclaus
Sep 3, 2015 06:15 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
yat70458
Aug 3, 2015 01:16 PM
