How to rotate unidirectional tires?
Old Nov 11, 2002 | 11:12 AM
maximawanabee's Avatar
I have Pilot Sport A/S' and on the sidewall it has the word ROTATION with a pointed arrow. Do you rotate these to the direction of the arrow? Does anyone picture what I'm talking 'bout?
Vyrus's Avatar
Re: How to rotate unidirectional tires?
Front to back.
-Cyrus
Old Nov 11, 2002 | 11:35 AM
nubiannupe's Avatar
OG Maxima.org Member
That word "rotation" refers to what direction the tire SHOULD be going when you're moving forward. Or to put it simpler, if you're sitting still, and that arrow isn't facing the front of the car, then you've got problems, bro!!
Old Nov 11, 2002 | 11:44 AM
gotcha!
Front to back.
-Cyrus
I knew that much
Old Nov 11, 2002 | 11:45 AM
sinewave's Avatar
If the arrow is on the top of the tire, it should be pointing forward, if it's on the bottom, it should be pointing rearward.
Old Nov 11, 2002 | 11:48 AM
Bluebird's Avatar
I am Roid Rage
Confusion
You could cause this guy some confusion. If the arrow is at the top it would be facing backwards while if it is at the bottom it would be facing backwards and vice versa. I know what you mean though.
Old Nov 11, 2002 | 01:23 PM
Myrv's Avatar
Re: Confusion
Um, errr... thanks for clearing that up.....?
Old Nov 11, 2002 | 01:31 PM
Bluebird's Avatar
I am Roid Rage
Re: Re: Confusion
Sure, anytime.
Old Nov 11, 2002 | 03:38 PM
JPMax's Avatar
What's next!?..
Unidirectional tires should only be rotated front to back and back to front on the same side.
No swapping sides of the car.
Old Nov 11, 2002 | 04:35 PM
sinewave's Avatar
I know some people who have the tires taken off of the rims so that they can flip the tire over, allowing a side to side rotation. Personally, I don't think it increases the life of the tires enough to offset the extra expense.
Old Nov 11, 2002 | 07:30 PM
dwapenyi's Avatar
When you rotate your tire, you guys notice how the fronts wear ALOT, and the rears wear so little, as if they're on vacation or something? I know that's what's supposed to happen, but I would think that the rears would wear a little. Usually I rotate my tires every other oil change.
DW
Old Nov 11, 2002 | 07:37 PM
Jamsan's Avatar
we do have fwd cars
Old Nov 11, 2002 | 09:41 PM
nadir_s's Avatar
vicodin ... gift of life
holy ****!!!!!!!! my arrows are pointing the other way!!!!!
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
