Are wheel seals and drive shaft seals the same thing?
Old Nov 14, 2002 | 12:22 AM
ßaller's Avatar
I had purchased these show in the pics below. Would they already have the drive shaft seal in them?
- ßaller
Old Nov 14, 2002 | 01:37 AM
Cutler's Avatar
I think the two seals are different, i may be wrong
Old Nov 14, 2002 | 04:21 AM
redmaxpa007's Avatar
i SeE what you did therE
aaa
not sure
turbomax95 would know
he breaks/replaces axels all the time
Old Nov 14, 2002 | 05:45 AM
deezo's Avatar
Ben would know, he's replaced his driveshafts.
Old Nov 14, 2002 | 02:07 PM
Stephen Max's Avatar
There are two seals in the differential housing part of the transmission. These are commonly referred to as the drive axle seals. They did not come with the axles you got, but they do not need to be replaced unless they are leaking. Since you are going to have access to them when replacing your axles, it may seem like a good idea to go ahead and replace the seals while you are at it, but be forewarned, they are a tight fit in the housing and it is easy to booger them up if you are not careful (the voice of experience here). Use a suitable size of pipe or large socket as a seal driver. Or get a seal driver kit.
vingodine
45
May 21, 2016 12:46 PM
maxinout93
Oct 27, 2015 01:29 PM
homeyclaus
Sep 3, 2015 06:15 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
