New Cams and Brakes
Old Nov 16, 2002 | 11:28 PM
i30krab's Avatar
New Cams and Brakes
I just found out I need another vacuum cannister for the brakes because the new JWT cam causes a drop in vacuum for the power assist at lower speeds! I picked it up at Summit for $39.95 and it comes with its own check valve. I also ordered the gauge to monitor the amount of vacuum. The gauge only costs $11.00.
I felt a loss of braking power since the engine rebuild and couldn't figure out the cause. Today I called Infiniti of Scottsdale parts and Jeff said the master cylinder and vacuum parts almost never go bad and then he asked didn't you get new cams? When I said yes he told me it had to be a vacuum problem and he was right. I didn't think the cams were radical enough to cause this problem. Go figure!!
Old Nov 17, 2002 | 12:02 AM
orgasmicNYC's Avatar
Re: New Cams and Brakes
I have a question do you do all the installations yourself. I see yuu post here with all the mods you get but do you install them yourself?
Old Nov 17, 2002 | 12:07 AM
i30krab's Avatar
It depends on what is being installed. When I need a lift or the work is too heavy I go to my friends garage and work on the car with them. Other smaller stuff I do in my garage.
Old Nov 17, 2002 | 06:12 AM
Black VQ's Avatar
So that means they have to be making some pretty good gains then.
Dyno time...
Old Nov 17, 2002 | 06:24 AM
Lime's Avatar
wow interesting! Thanks for the info!
Old Nov 17, 2002 | 08:39 AM
Matt93SE's Avatar
STFU n00b!
so what's the benefit of the new vacuum canister? larger, smaller, are you using it in addition to the OE one, or replacing it?
Just curious as to how it'll make the brakes work better with less vacuum in the engine....
Old Nov 17, 2002 | 09:42 AM
Anachronism's Avatar
The vacuum canister stores vacuum when the engine is making it (above idle) so it is available when it is needed (at idle). Kind of like a battery except it stores vacuum instead of electricity. The brakes work off the vacuum in the canister.
I am not sure if it replaces one or not though. I think a stock engine makes plenty of vacuum at idle so it may not need a vacuum canister but I could be wrong.
Old Nov 17, 2002 | 09:53 AM
i30krab's Avatar
The aftermarket cannister goes inline wiyh the oem cannister.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
