Yikes!! Just installed my Motivational Eng. rear strut mounts
Old Nov 21, 2002 | 12:25 PM
  #41
Dave B's Avatar
Not DAVEB the parts guy
Originally posted by ericdwong
Haha you guys must be old as *****, should buy a cadillac instead... j/k
anyway I have always been wondering about these things and if they really work. But they are sure expensive as *****. I guess if I keep this car I should look into this considering I've got cut sprints in the rear and a pretty heavy stereo.
My ***** aren't that old. They're 28.
The reason for the mounts is for a better ride AND better handling. They are expensive (~$132 shipped), but they're custon made. They're black powdercoated billet. IMO, they're worth the price.
Dave
Old Nov 21, 2002 | 12:53 PM
  #42
99DustMagnet's Avatar
will these work with a coilover system like Cattman's or JIC's?
Old Nov 21, 2002 | 01:30 PM
  #43
Nealoc187's Avatar
SLOW
Chunger do you have your front strut MOUNTS modified from stock. The issue I have is with front wheel travel, not rear. In the rear with my GCs down about 2.5" from stock, I've still got a good 2.5" of travel, with a spring as stiff as the GC, it's not an issue. But in the FRONT, I've got about 1" of travel, and this is with my bumpstop cut to 1/4 of its original size. It's the front of my car that needs suspension travel, not the rear.
Old Nov 21, 2002 | 03:54 PM
  #44
Mishmosh's Avatar
I have never been too bothered by the thump of the rear when going over a bump or two. It is the front that concerns me. Going over moderate bumps will send the front end/dash slamming pretty hard. In some cases, it actually seems like the front end is bottoming, especially if I set the Koni's to anything greater than a 3/4 turn stiff. Right now, have them on full soft up front which approximates stock ride but with appreciably diminished float.
The clunking of the rear end would be nice to rid of nonetheless. I can easily see how the mount might improve the ride after all, the shock action is not linear through the entire piston range. I am thinking that the toward the compressed end of the range, the ride suffers.
Old Nov 21, 2002 | 04:24 PM
  #45
Chunger's Avatar
My other car is a Hybrid
Mike can only modify Koni setups... It's not like the rear. He doesn't have modified front upper mounts... The strut insert and assembly are modified.
Have you considered getting a longer spring (eg 8" to 9") if your coils are binding? It would cost about $125 for a set of 2 coils.
Old Nov 21, 2002 | 04:52 PM
  #46
Nealoc187's Avatar
SLOW
The problem is that if I go with a spring that is longer my car will be that much higher off the ground.
Old Nov 21, 2002 | 05:24 PM
  #47
Chunger's Avatar
Not if you can move the lower spring perch lower.
I just swapped in longer springs into my friends DSM because he had coil bind... we went 1" longer with an increase of spring rate from 500 to 550lb/in... He was very happy.
Old Nov 21, 2002 | 06:37 PM
  #48
mitch33x's Avatar
Originally posted by Dave B
Look, for all you non-believers go ahead and believe what you want. Develop your therories and what not. I'm not a dumb guy and I consider myself pretty knowledgable when it comes to cars. I understand how and why this setup works so well. I know for a fact that everything about the ride in my car has dramatically improved from such a simple suspension modification. Yes, even cruising on a nice smooth rode feels even smoother. I got these mounts to add wheel travel, but I also got a better ride which I wasn't exactly expecting.
Dave, you have convinced me, a smoother ride for $132...to me thats worth it.
Old Nov 21, 2002 | 08:12 PM
  #49
Nealoc187's Avatar
SLOW
I can't, my spring perch is as low as it can physically go.
Old Nov 25, 2002 | 10:18 PM
  #50
theblue's Avatar
anybody else have trouble contacting them to order?
MaxStock
Aug 14, 2015 09:59 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
MaxStock
Aug 8, 2015 01:18 AM
laparka66
Aug 6, 2015 09:36 AM
