New dyno numbers
Old Nov 22, 2002 | 05:39 PM
MardiGrasMax's Avatar
New dyno numbers
I went to Swift Racing here in the DC area and did a quick three pulls on their dyno. My AFR needs a bit more tuning but its close enough for a base line before I do a full 3" Y-pipe and exhaust. I added a 2.62" pulley which gave peak boost of 13.5psi. I replaced the 2.5" crossover pipe with a 3" version. Replaced the HKS SSQ BOV with a Vortech Mondo BOV. I ported the MAF. I installed a 70mm throttle body and ported the intake manifold to match. I had to upgrade to 370cc injectors from a 96 300ZXTT. My FMU disc is now just a 3:1. I am using the J&S Ultra Safeguard to control some minor detonation above 10psi. It looks like I gained ~35hp & 35 ft/lbs in the midrange. I am happy with the gains but still need to change my exhaust. The current set up is a 2.5" Stillen Y pipe, 2.5" test pipe, 2.5" Courtsey B pipe and a tiny but quiet 2.25" variable capacity muffler from a 2000 Maxima. I should gain ~20-30hp & tq from a full 3" exhaust. Its on order so hopefully we will know soon.
Showing ~13.5psi on the boost gauge at redline.
Old Nov 22, 2002 | 05:42 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
What's new on the car that wasn't in the last dyno?
Old Nov 22, 2002 | 05:44 PM
4psi more boost
70mm throttle body
3" sc crossover pipe
370cc injectors
J&S Safeguard
Old Nov 22, 2002 | 05:55 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Cool.
Old Nov 22, 2002 | 06:01 PM
gtr_rider's Avatar
192.168.1.1
Originally posted by MardiGrasMax
70mm throttle body
It fit!
Old Nov 22, 2002 | 06:15 PM
Lordrandall's Avatar
Sweeeeeeeeet
Old Nov 22, 2002 | 06:36 PM
BigDogJonx's Avatar
Matt isnt the A/F ratio a bit low after 5600rpm? If you brought that closer to 11.5:1 wouldnt that alone bring the hp up a bit more?
Do you have an S-AFC or just the J&S for the knocking?
Dixit
Old Nov 22, 2002 | 07:25 PM
Cumalot's Avatar
Very nice Matt. Now time to take it to the track!
Old Nov 22, 2002 | 07:55 PM
dmontzsta's Avatar
Ford Only.
Do you have a MEVI?
Old Nov 22, 2002 | 07:56 PM
Delvin's Avatar
Damn. Thats all i have to say about that. Thats all i had to say when i seen under the hood for the first time. Keep up the good work.
Old Nov 22, 2002 | 08:11 PM
Confused's Avatar
Permanent Maxima.org Resident
Matt P Technology....
it is what it is and those is some nice numbers
Old Nov 22, 2002 | 09:24 PM
metallic97gxe's Avatar
Master Will
Old Nov 22, 2002 | 10:03 PM
dmontzsta's Avatar
Ford Only.
Well "DAMN" is all I gotta say, seeing that beautiful blue VE sitting in the grass
Old Nov 22, 2002 | 10:36 PM
emax02's Avatar
Not to shabby Congrats dude!
Old Nov 22, 2002 | 11:22 PM
SWEETSOUND2001's Avatar
I thought you'd gain a little more than that with extra 4psi.
Old Nov 23, 2002 | 12:17 AM
Y2KevSE's Avatar
He's not tuned up top... it's a little rich above 5000.
Old Nov 23, 2002 | 12:22 AM
Iron Lung's Avatar
The numbers look good. Imagine what the HP would be if you had a 7k redline. BTW how is the motor holding up? Any problems?
Old Nov 23, 2002 | 02:02 AM
SkylineGTR's Avatar
little?
Old Nov 23, 2002 | 04:32 AM
Swift has a package price for three pulls for $55.00, so I didnt have the pulls to get the AFR done exactly like I would have wanted it using my Fields AFC. After I install the 3" exhaust I will go back and get it tuned better. It just wasnt worth it to pay for more pulls since I will be redoing it in a litle while.
I thought it would be a little more with 4psi more. The need for a larger exhaust is really shown by this.
MEVI? Yes!
Old Nov 23, 2002 | 04:48 AM
The AFR tuning realy only helps the midrange. It may be an indication that an intercooler is needed The rich mixture cools the boosted air so leaning it out seems to not really work.
Old Nov 23, 2002 | 05:12 AM
Nismo87SE's Avatar
Re: New dyno numbers
I threw that dyno into cartest and it shows that with a 2.1x 60' you should run 13.0-13.1s @ 108-110mph on the motor. Also with a 6800rpm rev limiter your ET would be 1-2 tenths quicker and you'd add 1-1.5mph trapspeed too. You shouldn't fear the LS1s either, well at least the ones without heads/cams, from a roll that is hehe.
I went to Swift Racing here in the DC area and did a quick three pulls on their dyno. My AFR needs a bit more tuning but its close enough for a base line before I do a full 3" Y-pipe and exhaust. I only have a .jpg of it, I have to go back and get the data files so I can set it to match the other dynos. The smoothing on my older dyno is set at 5, this is at one so the power is lower. My old 319/265 dyno would show 313hp/260tq if the smoothing was set at 1. Apples to apples I gained ~23hp/26tq, so my new peak numbers set at the same smoothing level as the previous dyno would be ~342hp/301tq. I should have the data files next week so I can compare apples to apples. But the bottom line is I need a larger exhaust, the 2-1/4"2k muffler is choking me allot. With any luck I should have the 3" exaust set up from Warpspeed on some time in December and will re dyno then. I think I will pick up at least ~20hp/20tq from the exhaust.
Old Nov 23, 2002 | 05:37 AM
Re: Re: New dyno numbers
Thanks!
What does it look like if you use a 1.9 60', I have pulled that on slicks.
The only issue with the 6800 rpm limit is that I need a JWT ECU and they pull too much timing which will cause s loss of torque, plus I am already overdriving the blower at 6400rpms with a 2.62" pulley.
For poops and laughs could you add 20hp/20tq as if I had a full 3" exhaust and see what it turns out as?
M
Old Nov 23, 2002 | 10:04 AM
nismo2020's Avatar
Needs non-Maxima Friends
Originally posted by dmontzmax
Do you have a MEVI?
he has (almost)everything. he was the first with the vi i believe.
Old Nov 23, 2002 | 11:27 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
yeah the first one from roastbeast
after that roadbeef took the money and ran.
Old Nov 23, 2002 | 04:47 PM
crazy4maxima's Avatar
holey mother of maxima... wtf.. nice numbers. add a biiger shot of nos and see that puppy go up higher, just hope that nothing gets hurt
Old Nov 23, 2002 | 06:08 PM
Canuck's Avatar
Are you still planing on adding the intercooler?
Old Nov 23, 2002 | 09:39 PM
SR20DEN's Avatar
VQ Wizard
Great numbers Matt, keep up the good work. Perhaps it's time to retire that S-Trim for something that would do the job more effectively.
Old Nov 24, 2002 | 05:50 AM
Maybe a T trim, but 12's on street tires would me my goal.
Its an adiction though so you never no.
CAI any Y pipe, just couldnt get me their...
Tried the 60 shot of nitrous, after a while I needed more...
Tried the 100 shot of nitrous, but I needed it all the time...
9.5psi was good for a while, but I had to "speed ball" it with nitrous to make it feel good again...
13.5 psi is great, but I dont think I can stay with it forever...
It may be time for rehab, a Lincoln Town Car sounds realy nice
Old Nov 24, 2002 | 08:36 AM
SR20DEN's Avatar
VQ Wizard
DOH!! Not the Town Car.
I agree that the T-trim (maybe even a YS-trim) would be a wise option. Make more power with the same boost as a result of a higher adiabatic efficiency.
Old Nov 24, 2002 | 08:58 AM
SuDZ's Avatar
Are you against going with an intercooler for some reason? Just curious because of the ;rolleyes: you put after it.
SuDZ
Old Nov 24, 2002 | 09:02 AM
SR20DEN's Avatar
VQ Wizard
SuDZ
I doubt he's against it. It's just one more thing he would have to spend money on and add to the car. Probably close to the point where the hobby becomes a chore.
Old Nov 24, 2002 | 09:04 AM
SuDZ's Avatar
Gotcha. That is what I was thinking too.
SuDZ
Old Nov 24, 2002 | 11:07 AM
BINGO
An AWIC would be great! But I think I will be where I want to be with a 3" exhaust. I still have the juice to fall back on also, a 20-40 shot will be plenty.
I want to have the car tuned by the time the tracks open again. I dont want to be moding and tuning during racing season, I dont have that much free time available. My drag slicks also look very sad just sitting around.
Give three choice...
1) AWIC $1100
2) T Trim Blower $1200 w/exchange
3) 3.5L motor $1500
What do you guys think?
I really want the 3.5L, the 3.5L would have mad torque with boost. Plus it would give me time to do some basic port work on the heads. This would be in 8-12 months.
Old Nov 24, 2002 | 11:14 AM
How about AWD conversion so you can run 11's
Old Nov 24, 2002 | 11:44 AM
SR20DEN's Avatar
VQ Wizard
BINGO
1) AWIC $1100
3) 3.5L motor $1500
I agree. The VQ35 would be about the most bang for the buck. But the thing would make so much torque that it would be almost uncontrollable. With the lighter A32 chassis and the amount of power you would be making I would say that 3rd gear traction problems wouldn't be a suprize (on street tires). Plus doing a VQ35 motor swap would be more of an accomplishment than doing a T-trim swap.
But I know if you have the car long enough you'll eventually have them both.
Old Nov 24, 2002 | 01:53 PM
Gonna sponsor me with a nice set of rims?
Old Nov 24, 2002 | 10:11 PM
95emeraldgxe's Avatar
(give him some rims )
Old Nov 24, 2002 | 10:50 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
man oh man!!! good numbers Mardi, you're lucky I didn't show up in my SC'd 3rd gen, remember from the UM meet, I'm running that top secret 1.25" pulley!!! can't wait to see some track numbers next seaon!
Old Nov 25, 2002 | 06:40 AM
JAY25's Avatar
when you free flow your exhaust that should do it for sure. But Congrats those are some nice numbers.
Old Nov 25, 2002 | 12:28 PM
Redmax's Avatar
Redlinemax Owner
Originally posted by crazy4maxima
holey mother of maxima... wtf.. nice numbers. add a biiger shot of nos and see that puppy go up higher, :wall just hope that nothing gets hurt
u stupid!!
