View Poll Results: Who does not have a stock cat?
NO stock cat and NO problems
30
81.08%
NO stock cat and PROBLEMS
18.92%
Voters: 37. You may not vote on this poll
Who does not have a stock cat? And also does not get error code 420 that your cat is bad? Why me???? I have heard of like one other person that has to reset theres regularly. It does not make sense to me at all. I have a RT cat. I now have a custommaxima stright pipe to try out too. It seems a straight pipe would probably still send me a code though.
I am also getting the knock sensor code as well, are these related?
Any personal recommendations on a ODB2 scanner and data logger for a laptop or a Palm?
Do yourself a big favor, put your stock Cat back on. Trust me, I have been there and done it. I am happier than ever with OEM, with no CEL. I am assuming that you must have a Post Cat sensor, well I have tried 3 different Cats, and only OEM Cat won't give me P0420 error code.Originally posted by Prodeje79
Quote:
Originally posted by UMD_MaxSE
but lets see when emissions test time rolls around....
that's why you hold on to your cat, and mine is once every 2 years so hey, i can relax...Originally posted by UMD_MaxSE
i also have straight pipe..NO PROBLEMS
yup... still got my stock cat just for that reason Originally posted by meccanoble
or just find a shady emissions place
you only had your straight pipe a few days right? Originally posted by meccanoble
was it stock before that?
hehe
Actually......... my CEL went off tonight! Let's see how long it stays off! I have no emissions here either. I noticed a big power increase when I went WOT adn looked down to see my CEL had gone off. I hope it stays off....
Quote:
Originally posted by KrZyMaX
i have RT cat. no problems.
For those ppl who don't have problem with aftermarket Cat, do you have post Cat sensor? like fed emission cars usually have it? and if you do, do you have Y-pipe to go with it? Cuz it seems impossible for cars to have no CEL when you have Y Pipe, straight pipe/aftermarket Cat and your car have post Cat sensor????(unless your sensor is not functioning)Originally posted by KrZyMaX
Bascially, you took out all 3 Cats that came with the factory. One main one and 2 pre-cats.
So thats what my problem is....Originally posted by MaxTuner
yes, my whole piping is completeOriginally posted by MaxTuner
i have:
warpspeed y-pipe (removed two precats)
straight pipe (removed main cat)
and catback (b-pipe and muffler)
I have no CEL lights, and yes my cat was stock before that. I had a y-pipe but it didnt' take out the main cat....my car is also FEDERALLY spected and a 97...
i have:
Same as above, except for the straight pipe...Originally posted by meccanoble
i have:
Quote:
i know that the high-flow carsound cat will pass inspection, it's epa & carb approved. i just don't know if it will pass with a custom exhaust and y-pipe.Originally posted by MAX24
Former Sponsor
Quote:
Originally posted by MaximaRider
not sure but the 420 sure caught my eye, doh!
I was wondering too BUWAAHAHAHAHAHAHAI have the RT cat.. i wouldnt buy it again butcha know... its all good no CEL... next time straght pipe
Quote:
Originally posted by UTIMaxima
I'm cali spec, o2 sensor behind the cat, and I have had no problems. WSP y-pipe/carsound/courtesy b-pipe.
it's very hard to beat the 2.5" high-flow carsound cat, epa & carb approved with stainless steel at $97 with shipping.Originally posted by UTIMaxima
I have a Warpspeed Metallic Substrate Hi-flow cat.
I replaced my Y-pipe (WS), B-pipe (WS) and the cat all at the same time along with a new rear 02 sensor (from Nissan). The 02 threw an 0702 from the start and I have never been able to get it to clear (going on 3 months
Resetting the ECU clears it for a day or 2. I've pulled out the 02 several times and cleaned it but it will throw the code again and again. Anyone know of any solutions? I'm thinking of putting my stock back on.
Had to edit the code # it's was actually a 0702 bad Cat. code.
Thanks,
Boo
).Resetting the ECU clears it for a day or 2. I've pulled out the 02 several times and cleaned it but it will throw the code again and again. Anyone know of any solutions? I'm thinking of putting my stock back on.
Thanks,
Boo
Quote:
I replaced my Y-pipe (WS), B-pipe (WS) and the cat all at the same time along with a new rear 02 sensor (from Nissan). The 02 threw an 0707 from the start and I have never been able to get it to clear (going on 3 months
Thanks,
Boo
Make sure the wiring to the sensor is okay. Nothing pinched, shorted, etc.Originally posted by boo
Thanks,
Boo
i dont know why ud get a code sayin ur cats bad, thats not ur main cat. i have that code and i have a stock cat, the meaning of that code is bank 1 cat converter effiency is low, well obviously the effiency is low, its not there to be efficientOriginally posted by Prodeje79
so its not ur stock ur main cat u should be lookin at the P0420 code refers to your pre-cat assembley which the y-pipe replaces up to 00' unless urs is a 5th gen cali-spec or 01'. i cahnged my y-pipe a while ago and didnt get the SES light, but when i gutted out the front pre-cat the light went on. there are no 02 sensors after ur main cat for the ECU to know if its workin or not. if u need more info just ask, later.Quote:
well if u want to know what ur problem is why dont u swing by some time and ill scan ur ECU and see what codes pop up?Originally posted by Y2KSESteve
Quote:
Depends. If you have a cali spec car, there are no o2 sensors. But on a fed spec, there is an 02 sensor downstream of the cat (i.e. between cat and resonator.Originally posted by HitManSE
I have the 420 code with a cattman y and rt cat.
But, I started getting that code BEFORE I changed to the rt cat. Don't ask me why.
I've got a test pipe, and no error codes for 3 months now. Also i live in florida no emissions tests
Quote:
I thought it was the other way around?Originally posted by Max_Gator
alright that seems to make a bit more sense, u see mine is a 01' which are all cali-spec so to speak, i didnt know that the other max's had a O2 placed between the cat and the resonator. thnx 4 that info. only problem im gonna have here is emissions whenever that comes around, the SES light in my car wont shut off for long, when i clear it it stays that way for no more then 5min, or 1-2 miles.Originally posted by Max_Gator
Wow..really? I am okay with Stock Cat, Cattman Y and Greddy EVO(don't matter in this case).Originally posted by Max_Gator
and I am 2000 Fed Spec maxima. Maybe try checking the O2 sensors connection???
So, in conclusion, Carsound Cat won't give P0420 Code?..I know other ones will. At least for 5th gen Fed Spec Max!
To clear things up, Nissan ONLY makes Fed Emission max for 2000 Year, all 2001-UP are ALL California Emission--meaning, you will never get P0420 error code due to that there no O2 sensor behind the Main Cat.
And for ppl with 2001-up who have this CEL showing P0420, please CHECK THE TSBs, it has at least 3 TSBs released by Nissan that deal with CEL related to Emission Control system. That goes the same for P0420 error code.
Now, are there anyone with 5th gen Fed Spec Max that have Y-pipe, aftermarket Cat/straight pipe and Cat-back system don't have P0420 error code?
thx
wait, so now Im confused. I have a 97SE with a Stillen Y-pipe/stock cat..thinkin about getting a WS high flow. How do I know, other than buying it and installing it, if I will get the check engine light come on? What do I look for on the car? Does anybody recommend me doing this mod?
Thanks,
Boo
Some antiseize might have gotten on the O2 sensor when you were putting it in causing it to give you that code. Heard of it happening before with other people. Cleaning it with some electrical cleaner might help.Originally posted by boo
Thanks,
Boo
When I got my Warpspeed parts (Y, mettalic cat, B) there was quite a lot of antiseize in the holes for the sensors. Had to wipe some off.
Going on 4 months now without a code at all. Runs perfectly..
My SES (mine says service engine soon, not check engine soon) light came on again!!! AHHHHHHHHHHHHHHHH!
So I pull my codes, i get 3 codes
knock sensor
420
knock sensor
Same thing as 9 months ago!
Anyone else have luck with this?
I have a 97 SE 5 speed fed spec with old school Cattman SS ypipe, RT Cat, and greddy catback.
I have a test pipe I can install..... the 420 code seems to be for my missing precats though. hmmmmmmmmmmmmmm
Maybe my future JWT ecu will help
knock sensor
420
knock sensor
I have a Cattman Y-pipe = RT Cat (that has gutted it's self) = and Cattman B-pipe + factory muffler.
2000 Fed spec Maxima.
I called RT and they said that the reason my car gutted my cat is because of when my car was detonating form running too lean with my SC.
RT said that the basket inside the RT cat is made of ceramic and if it gets hit or back fires or detonates it will break that basket and then once it is loose it will come apart and pushed out of your exhaust in just a few days.
I have the same 0420 code all the time also.
RT offer to make me a custom cat with a metal basket for over $200. I am looking for other options.
There's a very good chance your cel will come on. 95-96 have a hard time with the cat moniter, so the ecm almost never checks the cat. 97+ doesn't have that 'problem.'
Quote:
I have a str8t pipe and never ever got a CEL for that. I do get occasional CELs but thats when something is wrong, like my EGT probe blowing off throwing all kinds of codes but that was the problem.
