compression test results from 12k mi Built motor
Old Jan 14, 2003 | 11:35 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
Cylinders
1 2 3 4 5 6
200 200 205 0 195 195
so uh yea....cylinder #4 is dead....
tests was done with full battery charge 5 cranks from starter motor. dropped some oil into #4 and retest with same results. i think a valve or spring went bad....so sad
Old Jan 15, 2003 | 12:02 AM
chinaonnitrous1's Avatar
Re: compression test results from 12k mi Built motor
Originally posted by Turbo95Max
Cylinders
1 2 3 4 5 6
Sorry matthel.. any way to fix that?
Old Jan 15, 2003 | 12:04 AM
krzymax's Avatar
Maxima owner since 2000
Re: Re: compression test results from 12k mi Built motor
*cough*postwhore*cough*
Old Jan 15, 2003 | 12:12 AM
hakk97se's Avatar
I agree
I'm really sorry to hear that Matt. Too much bad stuff going on this week
Old Jan 15, 2003 | 01:49 PM
AntGVR4's Avatar
did you leakdown test it ?
Ant
Old Jan 15, 2003 | 06:52 PM
max83's Avatar
Cylinders
1 2 3 4 5 6
What head work do you have done? Do you have OEM valves and valve springs or aftermarket?
Old Jan 15, 2003 | 10:15 PM
Jeff92se's Avatar
I'm needing a caw
There might be a way to replace the valve spring with the head on IF you get the air pressure to push the valve up and seal the head. #4 is the the back right? Will be harder but easier than doing a HG.
Old Jan 16, 2003 | 12:24 AM
Turbo95Max's Avatar
#4 is in front, the center one.
i have Ferrera SS valves and titanium keepers/retainers.
im juss gonna put in a stock motor....
Old Jan 16, 2003 | 06:30 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Old Jan 16, 2003 | 07:19 AM
Ramius83
So you aren't going to be getting rid of the Max yet, whew......
Good luck on the stock motor Matthel, the least you need now is another engine replacement....
BTW, do you have a spare non-locking 5-speed manual tranny sitting around????
Old Jan 16, 2003 | 08:33 AM
Jeff92se's Avatar
I'm needing a caw
Dude. If you can get to the valve spring by using compressed air, that would be 10x easier than swapping motors. Plus you would be swapping a weaker motor in. Keep the faith!
I just got done swapping motors. A big pain!
Old Jan 16, 2003 | 09:02 AM
MardiGrasMax's Avatar
Jeff's idea is worth a try.
Old Jan 16, 2003 | 10:42 AM
Turbo95Max's Avatar
thats assuming it is a bad valve spring. i havent looked into it more then the compression test.
i can get a used 5speed LSD with 24k on it for $900...interested??
AaronL
Aug 8, 2020 10:31 AM
Mar 12, 2020 12:06 AM
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
rbaker100
Sep 25, 2015 07:52 PM
