excessive vibration in the shifter caused by differential bearings?
Old Jan 16, 2003 | 02:09 PM
nadir_s's Avatar
vicodin ... gift of life
alright guys, everyone by now knows how poor I am and can't afford to fix the bearings YET... but for the past month or so I've gotten this excessive vibration in the shifter. When i grip it, i can feel it vibrating like hell and when i let go of it, it starts to rattle annoyingly (usually at 40+ mph). Do you think this is being caused by the differential bearings failure? BTW, this developed a month or two after i first started hearing the whining in my gears. Thanks
Old Jan 16, 2003 | 04:17 PM
I30tMikeD's Avatar
My bearings have all the signs of going bad, but no vibration.
Old Jan 16, 2003 | 04:37 PM
99Maxima5sp's Avatar
I have a sliiiight whine from like 1K to 2.2K or so in first gear and in reverse...
Will it just get worse? And will it hurt anything?
Old Jan 16, 2003 | 08:13 PM
nadir_s's Avatar
well I don't know if you really have it or not because u are either in the VERY VERY VERY beginning stage of it or it's probably normal... but if you do have it, you'll hear the whine all the way up till 5th gear like me!
Old Jan 16, 2003 | 08:48 PM
Jr'sMaxima's Avatar
What type of whine are we talking here???? Im guessing Id know if I have it?
Old Jan 16, 2003 | 09:16 PM
MaximaRider's Avatar
Nadir, this is the bearings? My ish has been vibrating like a biatch i thought it was the ypipe. it feels like the whole console including shifter is vibrating at low rpms? If this is the bearings i need to change them ASAP!
Old Jan 16, 2003 | 10:51 PM
I30tMikeD's Avatar
Other symptoms are; the previously stated high pitched wine, repeatedly leaking drive-axel seals(I have gone through three), and play in the axel.
It's either an expensive repair or a difficult DIY.
Old Jan 16, 2003 | 10:53 PM
acuratsx's Avatar
could it be your transmission?
m...you better get it fixed before you have to replace it...
but it seems to be sound badly...u might have to repalce it anyway
Old Jan 16, 2003 | 11:01 PM
I30tMikeD's Avatar
That is what were are basically talking about.
Old Jan 16, 2003 | 11:30 PM
iansw's Avatar
Ever thought of just tranny mounts/axles
It's not always the worst thing....don't go spending thousands before your'e sure.
IanS
Old Jan 17, 2003 | 08:03 AM
Dave B's Avatar
Not DAVEB the parts guy
There's no problem. My 96 has done this since I bought it nearly 4 years ago with 30K miles (currently 92K miles and lots of 1/4 mile fun). The whine you're wearing is the deep 1st and reverse gear ratios. Deeper gearing typically means more noise. If you get the noise in other gears, then you''ve got some problems.
Dave
user 11122324
42
Jul 18, 2022 03:35 PM
leatherneck
Sep 30, 2015 09:16 PM
uttadms31
Sep 30, 2015 05:24 AM
atriuum
Sep 28, 2015 01:19 PM
Pied
Sep 26, 2015 03:29 PM
