Will the Southwestautoworks Battery bar fit Optimas?
Just wondering if they would fit since it looks like the optima is slightly smaller than my current battery with the bar. Pics?
Re: Will the Southwestautoworks Battery bar fit Optimas?
Exactly what I was looking for
btw- did you put wood blocks under the battery? I heard they were shorter than stock batts.
Originally posted by MaximaZero
yea, the optimas are shorter than stock batteries. i went the ghetto way and used spacers to fill the gap between the battery and the tie bar.
Originally posted by chinaonnitrous1
its easy to THread down the poles..matthel helped me do it..took like 5 minits. You could cut the top of the posts..but i wouldnt
Most places sell Optimas with spacers attached on the bottom (as they come from the factory). Make sure you ask for one when you buy the battery, they are not additional charge. Mine sits just like the OEM battery with the spacer attached on the bottom. I bought mine from Advance AutoParts.
-Cyrus
-Cyrus
I put the little tie down bars in a vise and sawed off about an inch and a half or so.. whatever was needed.. made sure the top was flat with a grinder or sandpaper.. and ive never had any problems..
not on boards or anything else.
Speaking of Optima baterries
I went to a speed shop and asked them about the red top. The guy said I had to know how many CA(cranking amps?) I need before he can get me one. Is there a specific model or cold cranking amps that Max owners use?
Re: Speaking of Optima baterries
t6378tp
Sep 29, 2018 04:27 PM
Stagnet04
Sep 14, 2015 11:28 PM
markevans999
Sep 10, 2015 04:29 PM
