ppl with Injen beware!
Old Jan 24, 2003 | 08:57 PM
N1sMO's Avatar
My car would hesitate when I go WOT and it is not RPM dependant, meaning, it just freakin does it out of nowhere. So I checked for air leaks and couldn't find any. Took everything apart and started looking into the holes for the vacuum hoses and look at what I found.
(sorry for the bad pic, camera won't focus)
This is like leftover crap from the welds, the size of little rocks. And the picture was taken after I shoved my pinky in there and grabbed a **** load of it out already. There was also a lot of black dust which somebody said was left over from the polishing process. So that's what my car been sucking in for the past few weeks
Old Jan 24, 2003 | 09:00 PM
SterlingMist00's Avatar
Oh-oh...........time to take mine apart.
When did the hesitation start? Thanks for the heads up...
Old Jan 24, 2003 | 09:03 PM
99Maxima5sp's Avatar
wow, i think you should compain to Injen, at least so their more careful, thats insane!
Eric
Old Jan 24, 2003 | 09:18 PM
Maximam's Avatar
Old Jan 24, 2003 | 09:40 PM
chinaonnitrous1's Avatar
You should always inspect everythign before it goes on your car~! I always do..i cleaned my intake pipe with soap n' water before i put it on, and dried it throughly. I would inspect the flters for any tears. The same goes for any DIY job. You cant always trust the company to clean up. Its all up to you.
Old Jan 24, 2003 | 09:43 PM
Maximam's Avatar
Absolutely! I had to file metal burs off my Frankencar before install.
Old Jan 24, 2003 | 09:48 PM
Not only about dirt..but most of our stuff is made by hand....fabricated, assembled etc. Please dont tell me you inspect welds and such. Steve @ Franken car helped me out. I bought one of his intakes, had 2 pinhole spots in the weld. Talked to him, he send me another one a.s.a.p. so I wouldn't have any down time. Awesome guy, yes he does get backed up. But hes great! I've talked to many times...helped him with his stereo. Not to plug him or anything. I just dont want ppl to think he has poorly made stuff.
Old Jan 24, 2003 | 10:22 PM
N1sMO's Avatar
Ya, that was stupid of me to not check it throughly before installing. I cleaned it out, put everything back in and the car is running smooth... so I guess I lucked out
Old Jan 24, 2003 | 10:27 PM
N1sMO's Avatar
The hesitation started as soon as I put it in. It would happen sporadically. On one run, it would be smooth and then next, there would be a lag. But I drove the car after I cleaned everything and it hasn't hesitated yet... so I guess that was the cause.
Old Jan 24, 2003 | 11:44 PM
Maximam's Avatar
The large pipe had burs from the hole made to fit it. A quick file and it was fixed. Don't worry so much about backing Steve, I have no problems with his products.
Old Jan 25, 2003 | 02:06 AM
NYCe MaXiMa's Avatar
damn
Old Jan 25, 2003 | 02:26 AM
thnikkamax's Avatar
Ludicrous Speed
It's normal for the most part. When it comes to stuff for the intake, the welds are hardly ever done flawlessly.. you gotta run the ol' soap n' water routine. That's what I did to mine. You should check out your TB for further cleaning.
Old Jan 25, 2003 | 08:32 AM
Dave B's Avatar
Not DAVEB the parts guy
Is this the mid-pipe I'm looking at? If so, I'd be VERY concerned that metal debris has made it's way into the motor itself. Talk about significant damage. Just take a moment and think about how many places this metal will go thru before making it's way out, assuming it did get out and not get lodged or melted somewhere in the motor.
Dave
Old Jan 25, 2003 | 10:06 AM
N1sMO's Avatar
Dave
Yes, its the midpipe... That's the hole for the big vacuum hose. The stuff is not metal, more like solder... I can break up the pieces with my finger. Atleast its behind the MAF so those pieces didn't have a chance to run into it and jack it up.
Old Jan 25, 2003 | 12:53 PM
Green 2kSE's Avatar
Make sure you drain the oil asap but save some for an oil analysis in case there's significant metal shavings in your motor.
Old Jan 25, 2003 | 01:54 PM
CBass69187's Avatar
metal shavings
WOW I always inspect parts before they go on, but Injen shouldn't asume everyone does. They should be ready to install when they get to your door.
Old Jan 25, 2003 | 03:31 PM
Maximam's Avatar
Re: metal shavings
Absolutely!
Do we inspect the belts on our tires before we drive on them? How about checking for contamination in the oil we use to change with?
Exageration but metal burs and loose welds are a lack of quality control!
Old Jan 25, 2003 | 06:22 PM
redmaxpa007's Avatar
i SeE what you did therE
my car does that hesitating thing once and a while too..
gotta check out my injen..
Old Jan 25, 2003 | 06:26 PM
Craig Mack's Avatar
All YOUR grammer belong to me
You guys should just buy Superchargers...it will solve all these little problems.
Old Jan 25, 2003 | 06:31 PM
deezo's Avatar
Why the hell did you buy that thing for anyway?
Old Jan 25, 2003 | 06:35 PM
none of your damn beez wax..
Old Jan 25, 2003 | 06:44 PM
Vyrus's Avatar
Hey now... Jeff was being a pioneer. He was one of the first (if not the first) with the Injen. If it wasn't for him we wouldn't know how much they suck. Just kiddin' guys, I've never even seen one so don't personally.
-Cyrus
Old Jan 25, 2003 | 06:46 PM
Conrad283's Avatar
I need a truck
becuase it is red
Old Jan 25, 2003 | 06:47 PM
Originally posted by Conrad283
becuase it is red
HEy.. change your sig.. THEY LOST!!
Old Jan 25, 2003 | 06:50 PM
Conrad283's Avatar
I need a truck
i'll keep the sig up becuase they turned a 2-5 start into a trip to the second round of playoffs
Old Jan 25, 2003 | 06:55 PM
ny96max's Avatar
...WOW!! id be on the phone 1st thing Monday morning talking to Injen.
Ant
Old Jan 25, 2003 | 07:02 PM
gtr_rider's Avatar
192.168.1.1
Ant
Good work
TheMafia
Sep 4, 2015 08:26 AM
Dasmith
Aug 25, 2015 10:15 PM
The New CLIMAX
Mar 6, 2001 05:28 AM
