finally.... CLEAN engine bay!!!
Old Jan 26, 2003 | 11:00 PM
nadir_s's Avatar
vicodin ... gift of life
haha last summer i posted some questions about how to safely clean the engine bay... and i was flamed right to left for having such a filthy engine. Well i took Ben's advice.... degreased it... sorta clean but not shiny until yesterday. When i waxed my car, i decided to armor-all the inside so check out my before / after pics lol...
still need some help tho, there are hoses i can't get my hands to... shoudl i just degrease it? I did degrease the engine bay but was too scared to spray water in there to wash it down. Should I attempt this?
BEFORE
AFTER
Old Jan 26, 2003 | 11:04 PM
SaNdStoRm's Avatar
looks better w/o all that dirt heh...
clean up ur wires they're all over the place...
Old Jan 26, 2003 | 11:05 PM
Nismo's Avatar
the before pic was
anyways nice job but I heard that armorall is bad for the hoses I read here somewhere not too shure...
Old Jan 26, 2003 | 11:07 PM
dmontzsta's Avatar
Ford Only.
Originally posted by Nismo
the before pic was
Bling Bling.
What are those red wires? are those the ground wires I hear about?
Old Jan 26, 2003 | 11:16 PM
korupter's Avatar
is your air filter squashed into the fuse box?
Old Jan 27, 2003 | 08:55 AM
nadir_s's Avatar
Originally posted by dmontzmax
Bling Bling.
yeah, ghetto ground wire upgrade.... so ghetto I didn't feel like going out and buying black insulated wires for it haha so i just used the red ones that were lying around in my garage. Later i'll get some wireloom for 2 bucks (14ft) and cover that up so it's black.
Old Jan 27, 2003 | 09:06 AM
Street Reeper's Avatar
Handsome
Black Magic Tire Foam works pretty good for me. Just spray it all over and wipe down any excess. Cleans up the hoses and wires nice. But as far as the fire wall, that will take some degreasing or heavy buffing.
Old Jan 27, 2003 | 09:12 AM
Maximan190's Avatar
what kind of degreaser did you use?
last time i cleaned my engine i covered the battery and every wire harness i could see with pieces of plastic. I used some of my dads carb cleaner, sprayed it on the main visible surfaces - valve cover etc and let it sit for a few mins then washed it down with a power washer...took all the plastic pieces off and it started right up no problems
Old Jan 27, 2003 | 12:28 PM
dmontzsta's Avatar
Ford Only.
Did you notice a difference with the ground wires?
Old Jan 27, 2003 | 12:49 PM
mzmtg's Avatar
Minister of Silly Walks
I just use simple green every other time I wash the car. Cover the air filter with a plastic bag and rubber band. Soak everything with the degreaser, let it sit for about 5 minutes and hose it off with a gentle spray.
Old Jan 27, 2003 | 01:25 PM
JAY25's Avatar
so do you do you cover the harnesses or electrical connections or just spray, wait 5 mins and wash off.
Jesus my engine I don t clean but it does not look no where near yours in the before pic, looks like someone dumped a bag of dust into it. But great job cleaning it looks very nice and clean.
Old Jan 27, 2003 | 01:26 PM
Kevincleff's Avatar
Re: finally.... CLEAN engine bay!!!
BEFORE
Poor poor engine
Old Jan 27, 2003 | 01:29 PM
Dave B's Avatar
Not DAVEB the parts guy
From hear on out, there is no reason to keep using Armor All. All you need to do is wipe down the engine bay with a moist rag. Take a look at my homepage and you'll a pic of my motor. My Maxima is a 96 and all I do is dust and wipe out the engine bay 10 minutes every month. You guys are absolutely crazy to be using Simple Green and or washing your engine bays.
Dave
Old Jan 27, 2003 | 07:26 PM
Nismo's Avatar
Dave
Yep, I never degreased or use any cleaners to clean under the hood before. Wet cloth does the trick just fine.
http://images.cardomain.com/installs...0_101_full.jpg
Old Jan 27, 2003 | 09:45 PM
95emeraldgxe's Avatar
simple green is the best engine cleaner
Old Jan 27, 2003 | 09:53 PM
† ErV †
i scrub stubborn dirt with wd40.. must be safe enough; haven't killed my motor yet. the degreaser stuff i had to use once when i had the ps fluid leak and a big area was covered in layers of semi dry oil. but for the other parts i get some nasry white residue after the degreaser. so i just hand polish it with aluminum polish and wd40 and lots rags.
Old Jan 27, 2003 | 10:01 PM
MistaPeerez's Avatar
i might of done something bad cuz i washed my car at a car wash and they had a choice on there of engine degreaser...it just said spray all over and use spot free rinse after it...made it look good...but is it bad for it? ive only done it once..and before it looked bad like the engine in the pic
Old Jan 28, 2003 | 03:29 PM
lcf's Avatar
lcf
I chlorox the damn thing. It sparkles.
*tinkle tinkle*
Old Jan 28, 2003 | 10:56 PM
† ErV †
Originally posted by lcf
[B]I chlorox the damn thing. It sparkles.
*tinkle tinkle*
use lysol next time
Old Jan 28, 2003 | 11:13 PM
96BLUMAX's Avatar
Looks much better and simple green all the way.
Old Jan 29, 2003 | 10:39 PM
maxhead's Avatar
Do any of you who use Simplegreen find that the aluminum gets dull? I thought about using it but then read posts about it messing up the aluminum. I have plenty of that stuff & might use it this weekend.
Old Jan 29, 2003 | 10:45 PM
iansw's Avatar
BEFORE
AFTER
Wow - that first shot looks worse than my engine bay did after driving through 3 big dust storms in Phoenix last fall!!
Lookin good now - go buy some wire loom - it's cheap!
6spd4dsc
Mar 4, 2016 05:19 PM
Maximan190
Dec 16, 2015 06:01 AM
fastcarny
Oct 6, 2015 10:42 AM
aminus21
Sep 12, 2015 04:53 PM
03VQMAX
Sep 5, 2015 03:47 PM
