Sprint Springs pics link inside
Old Jan 10, 2001 | 02:24 PM
Nabil's Avatar
Pictures taken are of my '96 SE back on July 10, 2000 after being on my car for about a week.
These pics were kept under wraps and taken only for Sprint's R&D benefit... But now everyone can see how these prototype Sprints look on my car.
http://63.204.172.66/maxima/Sprints/Mavica.htm
--Nabil
'96 SE 5spd... Zesty!!!
Old Jan 10, 2001 | 02:34 PM
ryz's Avatar
ryz
I HAVE ????/
did you use an alingment kit when you installed those prototypes
Have you installed a regular set as yet or are you still running the prototypes
What recomendations did you make after running the spring
thanks
Old Jan 10, 2001 | 02:44 PM
Gotrice4's Avatar
Hey Nabil...
Is that a 2 inch drop? Looks subtle, how's the ride? How hard was the alignment? thanks.
Old Jan 10, 2001 | 03:02 PM
1MAX2NV's Avatar
A bit dark to see how big the wheel gap is. A picture like this might help.
http://www.geocities.com/tchangk2/Ma..._Pass_Side.jpg
--Nabil
Old Jan 10, 2001 | 03:13 PM
nismo96max
Is it me or does the back look a lot higher? Maybe it supposed to be like that, I might be just used to my heavy *** box in the trunk, and the car sitting very low in the back.
Adam
Old Jan 10, 2001 | 03:33 PM
MaxiPad96's Avatar
the front looks good but the rear looks jacked up compared to the fronts
Old Jan 10, 2001 | 03:38 PM
Lordrandall's Avatar
You guys are kidding, right? I think that height looks damn good!
Old Jan 10, 2001 | 03:55 PM
Nabil's Avatar
Ok folks... Keep in mind the pics are of my prototype springs... Also, the car wasn't sitting on level ground. Nevertheless, those prototypes do give it a ready-to-pounce stance which is very aggressive even when standing still.
I was told that Sprint liked this aggressive stance on my car and wanted to keep it in for the production sets, although I haven't installed my production set on my car to know for sure if they stuck with that idea.
As for the ride, these prototypes are even stiffer than my original Eibach springs, and have proven to be good on the track as I had the opportunity to run the car at Buttonwillow Raceway Park http://www.buttonwillowraceway.com on August 28th on configuration #13 CCW and where I duked it out with a Type R with coilovers the first session of the day driven by a seasoned driver/instructor and held my own nicely, which made me very proud as I consider myself a novice on that 3-mile track.
As for camber kits, yes you will need one for the fronts. However, I went another route to correct the camber at my local alignment shop http://www.fostertire.com and the guy modified my strut housings to correct for the camber variation. And they did an awesome job!!!
--Nabil
Old Jan 10, 2001 | 04:15 PM
kafene's Avatar
how much will they be?
and they look pretty nice! and for what generations will it be made for? 4th only? i know you been working on this for a little while now.
BkGreen97
Apr 2, 2016 05:47 AM
imported_Nismo_max
Feb 17, 2016 03:39 AM
Stagnet04
Sep 13, 2015 09:32 PM
lowpost99
Sep 8, 2015 05:06 AM
minsbang
Sep 5, 2015 05:36 AM
