Optima Red Top
Old Mar 8, 2003 | 09:29 PM
dmontzsta's Avatar
Ford Only.
Optima Red Top
is there something I can buy to make it sit higher? I tweaked out my j bar trying to get it spaced up, damn thing just sits too low. I know someone has invented something>????
Old Mar 8, 2003 | 09:49 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Re: Optima Red Top
piece of wood or something
Old Mar 8, 2003 | 09:51 PM
redmaxpa007's Avatar
i SeE what you did therE
Re: Re: Optima Red Top
Originally posted by Chris91SE
piece of wood
that is what i did...
Old Mar 8, 2003 | 09:52 PM
Sprint's Avatar
You can install an Optima battery in your car with very little modification. I have a Yellow top in my car. The OEM cables are long enough to reach the top terminals of an Optima Battery. The only modification you must do, is find some sort of spacer to put beneath the battery in the battery tray. I used scraps of 1/4" MDF. This is because the Optima Battery is shorter in height then the OEM battery. That plastic box that the OE battery comes with is not used. The OEM battery tie down and battery clamps will work. If your new Optima's battery has side terminals, I suggest double grounding the negative side by going to your local car parts store and buying a 24" 4 gauge side terminal battery clamp, and a side terminal for the battery. I put my second ground from the Optima's side terminal to the transmission mount's through bolt, although I had to slightly enlarge the battery cable's connector with a dremel.
The advantages of using a Yellow top are its deep cycle properties, mainly for high powered car stereo use.
For more info go to:
www.optimabatteries.com
- credit ericdwong
Old Mar 8, 2003 | 09:55 PM
dmontzsta's Avatar
Ford Only.
I guess its off to home depot to buy a fitted piece of wood...:cough: ghetto
Old Mar 8, 2003 | 09:57 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
hence the hiding smiley...us make it smaller so it's not noticeable
Old Mar 8, 2003 | 10:15 PM
DTR Maxima's Avatar
I am accenting my engine in a specific color. do i have to buy the whole optima battery, or can i just buy a colored top?? if so, where to i get it, i couldnt find it on the site
thanks, don
Old Mar 8, 2003 | 10:17 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
thanks, don
they're categorized/referred to base on the color...ie "red top optima" and "yellow top optima" etc
Old Mar 8, 2003 | 10:18 PM
Synki's Avatar
Old Mar 8, 2003 | 10:19 PM
thanks, don
paint you stock cover red..
Old Mar 8, 2003 | 10:24 PM
DTR Maxima's Avatar
well i was thinking about painting the engine top cover like many people have and then getting the colored wire loom, but would it look kinda cheap painting it? does optima just sell tops?
Old Mar 8, 2003 | 10:25 PM
no
Old Mar 8, 2003 | 10:30 PM
Vyrus's Avatar
Actually Optimas are supposed to come with spacers now. Go back to the place you bought it from and ask them if they have any. When I bought mine it came with one and it sit perfectly flush like the old one, but the manager told me they didn't always come with spacers. It's basically a big piece of plastic that clips on the bottom. Better than a piece of wood IMO but I wouldn't pay more than $5 for it.
-Cyrus
Old Mar 8, 2003 | 10:33 PM
-Cyrus
i have to go ask...
Old Mar 8, 2003 | 11:36 PM
nadir_s's Avatar
vicodin ... gift of life
haha looks like it's time to change your color engine's color scheme... you have 2 choices: red or yellow
Old Mar 9, 2003 | 07:40 AM
Kevincleff's Avatar
I go one with my red top!
Old Mar 9, 2003 | 07:44 AM
N34JZ's Avatar
Needs non-Maxima Friends
the point of buying the optima isnt for the colored top, its for a better battery and other reasons.
I think I threw my spacer out, I didnt think I would need it.
aw11power
Oct 10, 2021 04:57 AM
bigfrank
Oct 1, 2015 12:51 PM
Sep 27, 2015 08:37 AM
