Cleaning scratches dents
Old Mar 22, 2003 | 06:40 AM
flyer's Avatar
I had a **** do a minor hit and run on max, in my apartment complex parking lot. This was a few months back, don't know who the sofb is yet.
There is some green paint still on the dent, it's about 6 inches long and it's acroos the passenger and front and back doors.
I'd like to toake the green paint off, before I use some touch up on it, what can I use to take that paint off?
Old Mar 22, 2003 | 08:45 AM
95emeraldgxe's Avatar
if you attempt to remove the paint it might take off your car paint as well, i say just try to prime it and paint over it, paintscratch.com has all the tools available
Old Mar 22, 2003 | 09:36 AM
foodmanry's Avatar
Da Roller Coaster!
No it's possible to remove the paint. If it has taken off the clear coat and displaced that with the green paint then you can't really do a good job getting it looking like original.
I would try using a paint cleaner compound. Not rubbing compound because that will leave scratches. Meguire's makes a paint cleaner/wax combo. You are definitely going to need a high speed rotary buffer.
I have also heard that gasoline can remove that paint and won't harm the clearcoat. But be warned...I am not totally sure on this and I have never tried it myself.
Old Mar 22, 2003 | 10:54 AM
nadir_s's Avatar
vicodin ... gift of life
try claybar... then paint over it.
Old Mar 22, 2003 | 06:57 PM
flyer's Avatar
Originally posted by nadir_s
try claybar
what's that?
Old Mar 22, 2003 | 07:35 PM
foodmanry's Avatar
Da Roller Coaster!
Nah claybar won't remove paint too well. He can try it though...
It is used to remove contaminants from your paint. Stuff like embedded dirt and dust. You can feel it by running your hand along the paint (clean car) and if it's not smooth then you need to use a clay bar.
You can try it on the paint...but it won't work too well.
Old Mar 23, 2003 | 10:42 PM
Dave Holmes's Avatar
I'd try the clay bar first as the least aggressive means before any type of polish/compound. Clay bars were originally developed to remove paint overspray, not environmental contaminants, although they do a fine job of it. True polish most likely won't do it, as true polishes are designed to nourish the paint, not remove imperfections. Compounds are made to remove contaminants, but can be a double-edged sword if you don't have experience.
Try the least aggressive means first, even though it'll take longer to remove the foreign paint. Using something too aggressive first thing can take off too much of your car's clear/paint and/or leave scratches that will need worked out.
Dave
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
fx4five
Oct 1, 2015 04:58 AM
