Piccs of VQ35DE internals
http://members.verizon.net/~vze4yqyk...m_a_2002_m.htm
If some one wants to link them all, go right ahead.
Re: Piccs of VQ35DE internals
Looks good
Does it look like everything is going to fit together pretty easily? Any idea on a final displacement? I've read the hybrid 3.0/3.5L -> 3.3L discussions, but I haven't heard anything about it in a long time. The next weakest part is the block too right?
-hype
-hype
Originally posted by xHypex
Looks good
-hype
Looks good
-hype
+ 0.5mm = 3535cc's
+ 1.0mm = 3572cc's
It certainly does need a deck cap for high HP applications.
A few conclusions
1.) Notice the VQ35 cam lobes are cut to 1/2 thicknes on the preload side to reduce friction. The VQ30 cams aren't like that. This is one of the thigns I noticed on mine when I took the valve cover off.
2.) It looks as if the VQ35 cams can be used on the VQ30 head which is good because it's more aggressive.
3.) The VQ30 cam cannot be used in the VQ35 because it has no timing ring on it for the ECU to read.
4.) Nissan still isn't using oil spray jets from the block to cool the pistons. They're still using an oil spray orifice on the connecting rod to do this job instead. I wonder if there is avery good reason for this or are they being stubborn.
5.) The intake ports on the VQ35 head are not obviously larger than the VQ30 head but they are shaped differently. This would mean that the lower intake manifolds are not interhangeable between engines. A picture of a VQ30DE-K needs to be compared with these.
Got any crankshaft pictures??
The block does have under piston oil spray jets, I removed them when I pulled the pistons out.
The cams from the vQ35 will fit in a VQ30, but unless you use the variable cam control the power band will be off.
Crank, its in a box under allot of stuff, gimme a little while.
Rods look pretty whimpy though
Mardi,
Still going for 3.8 liters? If so, what are you going to do about the cylinder wall? Isn't it too thin to bore out that much?
I want to be the first one to hear a sound clip of your car if you succeed in that.
http://www.sprintmax.com/othercars/v...Engine-Project
I will pm you a username and password for you to upload if you like
do they seriously go on metrics for the motors?
if you bore it to far you can always sleeve it, just worry about hot spots in the walls.
one thing that is going to suck is the cost for a gasket set
if you find a good deal on one, please let me know, i need one for a VE.
good luck on the project. I dont think you can get too much more out of the heads and just watch out for the swirl patterns.
MrGone
MrGone
Wow thats phat. Just went to your website and say the list of new stuff, the new dyno results and the new track run. Congrats! Now maximas are actually really freakin fast. I guess i missed a lot while i was away from the forum.
I will be bored just the normal .020" over, trivial for displacment but important for a quality build. The heads will stay for the most part stock, perhaps some heat rejection coatings on the valves. Forced induction and nitrous does not really require the extra money to be spent on head work and cams, like NA would. Sure it would help a little but for the cost just juice it or boost it more, the question is the strength of the rods, pistons, head gasket etc. I am leaning toward o-ringing the head with a copper gasket, but with head studs and the factory MLS head gasket I might be ok. Or hopefully HKS or NISMO will come out with a solution for the deck issue. Rods, pistons, wrist pins, rings and ARP fastners including main studs and head studs instead of bolts are in development. The CR will end up ~9.3:1 with VQ30 heads, using what would be 8.5:1 pistons inside a normal VQ35 with VQ35 heads. 9.3:1cr will be pretty good for me I think. I'm in no rush, my goal is to have it ready to run for the winter.
for the copper head gasket seal problem, has anyone tried painting them with some High temp spray paint?
also if it is just leaking coolant, some high temp copper rtv should do the trick, just create a small bead around the water holes.
MrGone
MrGone
MrGone
MrGone
Id put it on like you would put Artic Silver thermal compound on a processor, paper thin. just enough to seal the itty bitty gaps that would be causing leaks. I had a feeling using the word "bead" would probably sound like alot, which I suppose it technically is.
So is this going to be a boosted motor?
MrGone
MrGone
MrGone
MrGone
James92SE
142
Jan 2, 2024 09:23 AM
6spd4dsc
Mar 4, 2016 05:19 PM
what is it?
