Will a Greddy for a 95 fit a 97???
Old Jan 15, 2001 | 12:08 PM
Max Speed's Avatar
Will the greddy exhaust for a 95 fit a 97? Thanks
Old Jan 15, 2001 | 12:12 PM
EuroMaxima99SE's Avatar
Caroline, U better keep me in mind if it would feet 97 that means 99 as well I hope
Old Jan 15, 2001 | 12:31 PM
Chunger's Avatar
My other car is a Hybrid
Depends if it's the new kit or the old one
The new ones will fit all 4th Gen... they offset the muffler further back plus the additional O2 fitting for the later ones.
Old Jan 15, 2001 | 12:43 PM
Stillnmax's Avatar
yes it will ... how do i know this ... i believe i have a 95 on my 99 .. there is a hole in a section of the b pipe for an O2 sensor since i dont have one i had to seal the hole up....
you can go to napa and they have a threaded cork to put in or you can do what i did and have it ark welded on...
=P
Old Jan 15, 2001 | 01:07 PM
Max Speed's Avatar
OOPS I meant 99 Not 97. Sorry stan
Old Jan 16, 2001 | 06:47 AM
=P
Is the piping for 95 the same size for 99?
Old Jan 16, 2001 | 11:56 AM
Stillnmax's Avatar
piping is the same except for that hole .. other than that its same ... =P
Old Jan 16, 2001 | 04:50 PM
Cumalot's Avatar
It should fit, but probably need some adjusting. I sold my Greddy exhaust to a guy that I know who had a '97 Maxima, mine's a '96. Although, the tip did look a bit weird because the tip didn't reach the edge of the rear bumper, just a bit short. Othen than that, it worked fine.
Old Jan 16, 2001 | 09:14 PM
How short was the exhaust? I mean was there a lot of space between the tip and the bumper? Is there anything I could do to adjust it and make it to the edge of the bumper, since I have a 99 model???
Old Jan 16, 2001 | 09:22 PM
Stillnmax's Avatar
its not that bad actually...
its only like 1cm short for me or so .. not really noticeable
Old Jan 16, 2001 | 09:27 PM
is there a lot of space between the bumper and the tip since you mentioned its gonna be shorter? is there anything I could do to adjust it?
Old Jan 16, 2001 | 10:23 PM
Phil02E46's Avatar
from what neel's said it really isn't that bad.. maybe a few mm or so.. i seen pics of his rear.. looks fine.. really if your not a maxima fanatic you wouldn't be able to tell the difference..
Old Jan 16, 2001 | 10:53 PM
TexMaximum's Avatar
I also have a slightly used one for sale. $400 OBO, shipped. Email me if you want it. less then 5K on the System.
Old Jan 17, 2001 | 06:48 AM
Neel, Do you by any chance have a pic of your rear w/ Greddy exhaust???
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
