Questions about GCs coilovers.
Old Mar 26, 2003 | 11:41 AM
99maxi's Avatar
i am putting the GCs on the AGXs. i know i need to grind down the diamond shape to put the sleeve onto the strut. with that done it seems like there is a few inches between the top of the spring and the metal top hat. is it supposed to be like that? and are there any problems like noise and stuff??
Old Mar 26, 2003 | 12:00 PM
ejj's Avatar
ejj
Re: Questions about GCs coilovers.
Yes, that space will of course disappear when the weight of the car is lowered onto them.
Old Mar 26, 2003 | 12:05 PM
99maxi's Avatar
i know, but what happens when i hit the bumps and the plate and spring seperate and come back together?? any noise?
Old Mar 26, 2003 | 12:13 PM
ejj's Avatar
ejj
You'd have to get airborn, or damn close to it for the top hat to lift off the spring. In that case, yes, I'm sure it would make a LOT of noise.
Hasn't happend to me in over a year of driving with them.
Old Mar 26, 2003 | 12:17 PM
99maxi's Avatar
what else did u change when u did the install? how long did the instal take?
Old Mar 26, 2003 | 12:20 PM
ejj's Avatar
ejj
I installed GC's and AGX's. Took me about 4 hours. This was the 4th or 5th time I'd done a suspension install though.
First time I did it I planned on a entire weekend...although it didn't take nearly that long.
Old Mar 26, 2003 | 05:27 PM
99maxi's Avatar
were u able to find dust boots? and also what bump stops did u use??
Old Mar 26, 2003 | 05:39 PM
redmaxpa007's Avatar
i SeE what you did therE
you will have noise..
Old Mar 26, 2003 | 05:49 PM
Kevincleff's Avatar
Not as bad as yours
Old Mar 26, 2003 | 05:51 PM
Originally posted by Kevincleff
Not as bad as yours
actually worse..
but i know how to fix mine.. i just need to find the items i need
Old Mar 26, 2003 | 06:56 PM
rob van dam's Avatar
actually worse..
hey jeff,
you need those rubber disks like i have..dont you?
Old Mar 26, 2003 | 06:57 PM
Originally posted by rob van dam
hey jeff,
yes
hey jeff,
yes
Old Mar 26, 2003 | 07:00 PM
yes
go to a local suspension shop and ask for "rubber o rings" or "rubber disks" to fit above and below your coilover springs.....the shop that did my install gave them to me for free...so you might get lucky....
Old Mar 26, 2003 | 07:03 PM
i been searching locally for them
i will find something
Old Mar 26, 2003 | 07:05 PM
....hey jeff...send me one of your left over bulb sleeves.....so i can put it on my gauges....
Old Mar 26, 2003 | 07:09 PM
i used all three..
Old Mar 26, 2003 | 09:20 PM
Matt93SE's Avatar
STFU n00b!
Energy suspension sells the spring rubbers. look on their webpage and you'll find them there.
Should be able to order them from most race shops that sell springs and coilover parts.
Anybody know of any dust boots that'll fit under the 2.5" springs?
ruined a pair of Tokico struts in a few months because the sand ate the seals on it from not having dust boots in it.
Old Mar 26, 2003 | 09:43 PM
99maxi's Avatar
i am looking for dust boots that fit in the GC coilover springs.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
