95 max digital climate bulbs
Old Mar 30, 2003 | 01:39 PM
java's Avatar
Has anyone replaced the bulbs in the climate control. None of mine worked and I took it apart and they all appear to be burned out. I checked around and can't find them anywhere. Can they be replaced with led's from radio shack or something or is there a place to get replacement bulbs? Thanks in advance for your help!
Old Mar 30, 2003 | 05:16 PM
tecman4's Avatar
all LED's use the same voltage of .7 volts so it should be ok, just make sure they are the proper size to fit and also you would neep to put them in the correct way.
If you put a LED in backwards you will burn out the LED.
LED's rarely burn out though (like the LED on your computer power light)so I would make sure that you don't have an electrial problem or maybe a fuse blew out. or maybe they are not LED's but low watt bulbs in which case you would need to find a bulb that is the correct voltage and wattage.
I would bring it to the dealership, they would have the exact type required and would know how to put them in.
Old Mar 30, 2003 | 05:43 PM
Cutler's Avatar
Get them from the dealer, very easy to change
mikeg75
Nov 30, 2015 05:12 PM
meccanj98
Sep 16, 2015 07:23 AM
EdRomo86
Sep 12, 2015 07:49 PM
