Will these tires fit on my rims?
Old Mar 31, 2003 | 08:11 AM
shaz's Avatar
NEED HELP ASAP! Will these tires fit on my rims?
Will a set of 235/40-18 fit on a set of Konig Reign 18X7.5 rims? 45 offset btw. Possible rubbing issues? These are on a 98 Max with H&R springs...Thanks
shaz
Old Mar 31, 2003 | 08:50 AM
ch13f's Avatar
you should be fine.. lots of people are running a similar setup without problems.
Old Mar 31, 2003 | 08:58 AM
shaz's Avatar
OK, thanks very much
shaz
Old Mar 31, 2003 | 09:31 AM
shaz's Avatar
OK, so now I talk to the lady at tirerack and she tells me that 235/40's wont fit on an 18X7.5 rim?? I thought they would fit fine? So I call a local tire shop, HE tells me since I'm lowering the car to get 225/40's. But the lady at tirerack said the load bearing of the tire isnt enough for my car? Which is what all started this in the first place. PLEASE HELP! christ
shaz
Old Mar 31, 2003 | 09:55 AM
99Maxima5sp's Avatar
shaz
ignore her, you'll be fine...
eric
Old Mar 31, 2003 | 10:33 AM
shaz's Avatar
eric
OK but which ones should I get then? A 98 Max with H&R's, 18'' Konigs. The 225's or the 235's?
shaz
Old Mar 31, 2003 | 10:37 AM
abstrakt79's Avatar
It's up to you, the 225/40s will have a sidewall of 3.54in and the 235/40s will have a sidewall of 3.70in...really not much of a difference...i'm ruinning 225/40s...check my homepage for pics...the 235s won't be much taller...by the way, i'm running H&Rs w/18s as well
Old Mar 31, 2003 | 11:00 AM
go with 235, just because their slightly thicker and taller, IMO the thicker the better, i dont like rubberband tires. If it was me, id be running 235/45-18s
eric
Old Mar 31, 2003 | 12:14 PM
shaz's Avatar
eric
Also keep in mind my rims have a 45mm offset...so theyre a little closer in to the wheel well...still 235/40's will be OK?
shaz
Old Apr 3, 2003 | 05:54 PM
A-Ron Max's Avatar
I have those spec tires on my 18x7.5 subzeros, so you'll be fine.
Old Apr 3, 2003 | 06:01 PM
asu174's Avatar
Clay Aiken has fancy genitals
She's not telling you this because they will rub. She's telling you this because 235/40 is out of spec on an 18x7.5" wheel. The widest the National Tire Association recommends is 225 40 18.
If you run a 235 40 18 on that wheel, you will definitely have no warranty on them.
Mar 12, 2020 12:06 AM
spazma7ik
Jan 12, 2017 09:38 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
0m3nc0w
Sep 11, 2015 05:21 PM
adamgalazka
Sep 8, 2015 01:27 PM
