Another 4th gen N/A auto in 14s
Old Apr 5, 2003 | 07:26 PM
CHI99Limited's Avatar
Nealoc187, Max2000JP,I30TMikeD and I took a trip to race at Byron today. Well we all ran in the 14s or better with Neal doing exceptionally well. My personal best....
60' 2.373
330 6.437
1/8 9.717@76.24
1000 12.558
1/4 14.964@94.63
Best trap of the day was a 14.967@95.05(60' 2.394). Mods included y-pipe, intake, and catback. Was running stock 99 se rims and tires on 35 psi.
Old Apr 5, 2003 | 07:32 PM
Sprint's Avatar
14.9 with your mods and a 2.3 60ft? is this track downhill or something?
Old Apr 5, 2003 | 07:45 PM
Nealoc187's Avatar
SLOW
Adam's car is just fast. He ran 15.6 @ 92 last year with a 2.7 60' time at a different track, a track that is notoriously slow.
Old Apr 5, 2003 | 07:46 PM
Sprint's Avatar
someone slap me
Old Apr 5, 2003 | 08:08 PM
MAX2000JP's Avatar
I ran a 14.91X with a 2.37 60' in my brothers car. If the car could get off the line it would be interesting.
Old Apr 5, 2003 | 08:22 PM
costcowholesale's Avatar
did you manual shift? leave it in D?
Old Apr 5, 2003 | 08:37 PM
Nealoc187's Avatar
SLOW
Manually shifting.
Old Apr 5, 2003 | 09:18 PM
Shoooter_j's Avatar
Manually shifting.
@ what rpm did he shift?
Old Apr 5, 2003 | 09:26 PM
NYCe MaXiMa's Avatar
what the..
nice!
Old Apr 5, 2003 | 10:09 PM
VeeTec's Avatar
Get that launch down and you should be seeing mid 14's fairly easily.
Old Apr 5, 2003 | 10:11 PM
Synki's Avatar
Have you made any passes on just "D"? I got my best times leaving it in "D". When I manually shifted, I notice dmy trans took longer to shift. I see it, let the transmission do whats its uppose to do, shift on its own. THis is just IMHO and based on my results.
Consider some slick and you will reduce that 60ft. 60ft will make you or break you.
What are you launching at? I use to torque flash @ 1700rpms on stock TC.
Old Apr 6, 2003 | 06:52 AM
Victim64's Avatar
Yep, that time is VERY fast for an auto. I am not positive, but I don't think 96sleeper hit 14's without his ecu or vb?
nice time!
Old Apr 6, 2003 | 07:59 AM
I30tMikeD's Avatar
I sure hope he does not get an better at his launch. He will be giving me a run for my money if he does.
Congrats.
Old Apr 6, 2003 | 08:04 AM
MaxEffect414's Avatar
I have a 99SE-L and i ran a 14.8....
I have intake, Port&polish stage 1, and a magna flow muffler, that's it.
Trance
Old Apr 6, 2003 | 09:02 AM
Victim64's Avatar
Trance
Are you auto>?
Old Apr 6, 2003 | 10:17 AM
96sleeper's Avatar
That mph is very high for those mods, I didn't start running over 92-93 mph until I got the VI. And I never ran a 14.9 before without a 2.2x 60 ft time. You car might be a freak..or the track is a little downhill.
Old Apr 6, 2003 | 12:04 PM
Street Reeper's Avatar
Handsome
What kind of tires?? Thats great with those mods
Old Apr 6, 2003 | 01:23 PM
deezo's Avatar
At least the track doesn't go uphill like the one at Maxus 2001.
Old Apr 6, 2003 | 02:59 PM
MAX2000JP's Avatar
Originally posted by slammed95
http://www.imagestation.com/album/?i...34344454&idx=9
The track looks downhill to me. I really don't believe in "factory freaks."
Thats an optical illusion.....
Old Apr 6, 2003 | 08:32 PM
Victim64's Avatar
Its a very good one!
Old Apr 7, 2003 | 10:11 AM
ZeRo--MaX's Avatar
What RPM did you shift?? what rpm did you brake torque??
Old Apr 7, 2003 | 01:23 PM
I shifted the car at around 6200 each time and brake torques were all different. I ran the car 22 times and found out shifting yourslef is the only way to go. Leaving it in drive i couldnt do better than 15.2@93.....shifting myself i was running no worse than 15.1@almost 94 or better each time. I had four runs in the 14s once i started shifting manually.
Old Apr 7, 2003 | 02:57 PM
ZeRo--MaX's Avatar
Did you have the resistor mod? Or just normal?
Resistor mod
Old Apr 7, 2003 | 03:24 PM
Nealoc187's Avatar
SLOW
Resistor mod
he doesn't have the resistor mod.
Old Apr 7, 2003 | 06:06 PM
MR_Maxi's Avatar
Could someone please give me a link to the resistor mod.
Old Apr 7, 2003 | 06:16 PM
ZeRo--MaX's Avatar
Sorry about that...
Here it is...
http://forums.maxima.org/showthread....hreadid=195865
Hope it works....
He doesnt have the resistor mod?!?! does he have VB?
He would pull alot faster if he had the resistor mod
Old Apr 7, 2003 | 06:26 PM
Nealoc187's Avatar
SLOW
Sorry about that...
Here it is...
Hope it works....
His mods are as it says in his sig, no more no less. He's been looking for a new car for like a year now. He's not going to spending more money on this one.
Old Apr 7, 2003 | 08:21 PM
MAX2000JP's Avatar
BTW...The UDP is not on his car. He has had it for about a year and never installed it. I bet with a UDP and better 60' times his car COULD run a 14.5
Old Apr 8, 2003 | 10:22 AM
BC_95GLE's Avatar
14's na auto thats nutz i'm so close to getting in the 14's with my car right now i have the resistor mod right now it knocked off a little bit in my times i just cant break into the 14's yet i'm working on different rims size and tire combinations to see if i can make it into the 14's this summer hopefully removing the cat with a test pipe will help along with a few other things. Brian
MAXSE5SPD
Sep 17, 2022 04:00 AM
I<3 A32's
Sep 10, 2015 11:07 AM
Maxboy23
Sep 4, 2015 06:04 PM
Lowered_a33
Sep 1, 2015 07:49 PM
