Brake Squeel Spray...any good?
Old Apr 7, 2003 | 04:31 AM
LouE37's Avatar
I bought some brake squeel spray because i didnt want to have to take off my brake pads to get rid of the noise. Basically it says to just spray on the rotor all around and should cure the problem. Anyone ever use this stuff and with some results? Im hoping it works because the noise is so aggravating.
Old Apr 7, 2003 | 05:07 AM
Maxman2000's Avatar
Mine does the same but the brakes have to be wet and have a little rust on them. Or very cold (yes it is annoying). No, I've never used it.
Old Apr 7, 2003 | 05:25 AM
njmaxseltd's Avatar
I've never heard of an anti-squeal you spray on your rotors. Makes no sense, one stop and your pads will have wipped away anything that was applied.
Anti-squeal lubricants must be applied to the back of the brake pads and shims.
Old Apr 7, 2003 | 05:33 AM
deezo's Avatar
Exactly. Change your pads. I'm running Nissan pads in the rear and carbon-metallics in the front, no more squeals.
Old Apr 7, 2003 | 05:34 AM
LouE37's Avatar
I already changed my pads (all 4)less than 6 months ago...now all of a sudden they are sqealing!
Old Apr 7, 2003 | 05:41 AM
deezo's Avatar
What are they?
Old Apr 7, 2003 | 05:45 AM
LouE37's Avatar
What are they?
Raybestos Quiet Stop...how ironic huh!!!
Old Apr 7, 2003 | 06:05 AM
jun's Avatar
jun
spray does not work
i used the braklen spray for m 2k2 rear slotted rotors, squeel goes away when the rotors and calipers are wet but when they are all dried out the squeel comes back
Old Apr 7, 2003 | 06:21 AM
optimus1's Avatar
anti-sqeal spray
You spray the stuff on the back of the pads to absorb the vibration, which is the squealing sound ...
Old Apr 7, 2003 | 11:53 AM
ZeRo MaX's Avatar
tell me if the spray works.. cuz when i changed my pads... (OEM)... i started to hear some bad squealing... so need to find some good brake pads or use the spray...
Old Apr 7, 2003 | 02:07 PM
deezo's Avatar
Me and Ben always recommend the carbon metallic pads but noone ever listens.....
Old Apr 7, 2003 | 02:42 PM
athlon omega's Avatar
The ones from autozone? I have those and a week and a half after changing to them from Raybestos brakes, they started squeeling again. What should I do? I figure that spray could somehow seep into the backs of the brake pads since the side-caliper area isn't air tight.
Old Apr 7, 2003 | 04:50 PM
nadir_s's Avatar
vicodin ... gift of life
when you change your brakpad just put a whole mess of anti-squeel glue on the back between the shims and the brake pads. Sure some of it will start dripping... just wipe it off.
In my case, my brakes came w/ the car and they squeeled soooooo bad... then i found out that the rear brakes don't have shims and the front ones have shims but no glue between them and the pads! so i just put the glue and they stopped squeeling.
anti-squeel glue on the back of the pads... in the other hand is the shim:
yum
Old Apr 7, 2003 | 05:07 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
I recommmend CRC Disc Brake Quiet anti-squeal compound. Its orange, thick, doesn't drip when you apply it and IMO better than anything else out there.
Old Apr 7, 2003 | 05:10 PM
deezo's Avatar
Do what nadir_s recommends above. Are you using the shims with the pads?
Old Apr 7, 2003 | 05:12 PM
metallic97gxe's Avatar
Master Will
yum
I need to put some of that on mine!
Old Apr 7, 2003 | 07:58 PM
ZeRo MaX's Avatar
yum
DOES THAT REALLY WORK GOOD?!
Old Apr 7, 2003 | 09:46 PM
I beleive so. At least that's what I think. I had a mechanic put it on. I'll call them tomorrow and tell them about the squeeling. Hopefully, they can apply the brake quiet stuff to it for free.
Old Apr 7, 2003 | 10:06 PM
nadir_s's Avatar
if you put the shims on w/ the anti-brake glue then it's POINTLESS putting the shims on.
They worked well for me! I don't have any squeeling anymore!! ( at least in the front where i put it... gotta do the rears now).
Matt93SE
May 24, 2019 02:58 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
rbuswell
Nov 17, 2016 04:54 AM
pkfinn
Jan 3, 2016 02:55 PM
homeyclaus
Sep 3, 2015 06:15 PM
