All Interested In Copper Head Gaskets
Old Apr 9, 2003 | 04:46 PM
max83's Avatar
I spoke a while ago about having SCE make copper head gaskets, after a long wait they are in production! They will be finished either Friday or Monday.
They are as close to OEM as possible. The pricing is $100.
They have produced eight sets if anyone is interested.
Old Apr 9, 2003 | 09:42 PM
Ramius83
Who do we contact for the head gaskets, you or them????
Old Apr 9, 2003 | 10:03 PM
max83's Avatar
Me
Old Apr 10, 2003 | 01:03 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
you know im down for 2 sets.....finally
Old Apr 10, 2003 | 11:16 AM
iansw's Avatar
These head Gaskets are purely to make the engine even more stable to power, correct?
Sounds good to me...
Old Apr 10, 2003 | 11:22 AM
MAXIN's Avatar
[noob]how long should it take to swap head gaskets and how hard is it?[/noob]
Old Apr 10, 2003 | 12:37 PM
Turbo95Max's Avatar
its not easy. espically on the car, on the car i estimate at least 8 hours.
Old Apr 10, 2003 | 02:26 PM
MAXIN's Avatar
thanx.
Old Apr 11, 2003 | 10:02 PM
max83's Avatar
So thats two... Where is everyone else who expressed interest when the topic came up before?
Old Apr 12, 2003 | 05:22 AM
MardiGrasMax's Avatar
for VQ30 or VQ35
Old Apr 12, 2003 | 07:26 AM
n2oMike's Avatar
Most people racing domestic V8's running tons of boost or nitrous use copper head gaskets AND groove the block around the cylinders for wire. The wire is set into the grooves, then the copper gasket is laid down on top. The wire presses into the copper, producing a VERY tight seal. It's called 'O-ringing' the block.
However, water leaks are more of a problem with copper gaskets, so the gasket needs to be thoroughly cleaned with solvent, then sprayed with a few coats of copper 'spray-a-gasket'. After it starts to get dry and tacky, install the gasket onto the block, then install the head. Water leaks are PITA with copper.
Anyone considering copper gaskets and/or O-ringing should search the internet for information on doing it right... as it would SUCK to have to re-do the job on a Maxima if they started leaking!
Here's a place to start...
http://www.fast-eddys.com/openbb/rea...print&TID=1500
Good Luck!
Old Apr 12, 2003 | 09:05 AM
max83's Avatar
Originally posted by MardiGrasMax
for VQ30 or VQ35
VQ30
The O-ringing the block is a debateable issue. It'll all depends on the clamping force of the head to block.
Most V-8 do not need to O-ring the block. I have spoken with SCE and the belive that we should be ok without O-ringing the block.
If everyone would prefer it I can have SCE create an O-ring kit that should be under $20.
Old Apr 12, 2003 | 11:24 AM
redmaxpa007's Avatar
i SeE what you did therE
i know tilleys99 is looking for these
i will let him know
Old Apr 12, 2003 | 03:00 PM
max83's Avatar
i will let him know
Thank you
Old May 5, 2003 | 06:22 PM
TILLEYS99's Avatar
Lives in a 11sec maxima
I want a set!
Old May 5, 2003 | 06:29 PM
max83's Avatar
So I have 3 people interested? I still have 5 more left.
Old May 5, 2003 | 07:41 PM
Turbo95Max's Avatar
how do we buy them?
Old May 6, 2003 | 11:27 AM
Dreizehn's Avatar
I'm 98.8076582325% sure I want a set...
How do we buy them...
Old May 6, 2003 | 02:02 PM
max83's Avatar
When I get the 8 people willing to buy, I will send them out.
Old May 6, 2003 | 06:11 PM
Turbo95Max's Avatar
well you gotta give more info on where to order from. where to send money. how long itll take. all that crap.
im down for 2 sets and im still waiting....
Old May 7, 2003 | 06:05 AM
Dreizehn's Avatar
Old May 19, 2003 | 04:20 PM
max83's Avatar
The gaskets have been made just waiting for four more people.
Old May 19, 2003 | 04:42 PM
Confused's Avatar
Permanent Maxima.org Resident
got pics?
Old May 19, 2003 | 04:48 PM
max83's Avatar
No sorry the gaskets are at SCE until I have the 4 other people to go ahead and have them sent out.
Old May 19, 2003 | 05:31 PM
What about with a larger bore for a VQ35?
Old May 19, 2003 | 10:33 PM
max83's Avatar
I'm sorry the gaskets were all ready in production when I called about that. If there would be enough interest I could see if they would make sets for the VQ35.
Old May 20, 2003 | 06:18 AM
Dreizehn's Avatar
What if we don't get four more people? Can we still get ours?
Old May 20, 2003 | 05:54 PM
max83's Avatar
Not sure, I would have to front the money for the other gaskets and then hope that they would sell later.
Old May 21, 2003 | 06:24 AM
Dreizehn's Avatar
SCE won't sell them one at a time?
Old May 21, 2003 | 09:55 AM
max83's Avatar
Nope, I hade to agree to 8 to waive the $400+ engineering fee. When I brought this topic up to see if there was enough interest there was more than people interested.
Old May 21, 2003 | 10:02 AM
SR20DEN's Avatar
VQ Wizard
You guys are about to open Pandoras box, asking for copper head gaskets.
Old May 21, 2003 | 10:17 AM
Dreizehn's Avatar
Please continue...
Old May 21, 2003 | 10:18 AM
max83's Avatar
Yes please go on, I am confused by what you mean.
Old May 21, 2003 | 10:38 AM
SR20DEN's Avatar
VQ Wizard
He said most of it right there. Copper gaskets are not advised for street use. They will leak. And honestly who in here has ever blown the stock gastkets and how many VQ's have you seen on the road blowing blue smoke because of blown gaskets? They will handle more power than the rods will. And the softer copper isn't going to make the deck any stronger. If you're really worried about the deck strength you should have a cap made or have it welded up then deck and hone the block. And even if you get them, many of you don't know how much of a PITA you're asking fo to put them on. To remove the heads you must first have the entire front cover removed and the front cam journal cap. To remove the front cover you must have the bottom cover removed. To remove the bottom cover you must have the transmission removed.
I just don't see that such a thing is needed, especially if most people aren't even approacing the hp levels needed to even think about new head gaskets. Save your money and put it somewhere else that will be of good use like rods or pistons or a deck cap.
Just my .02
Old May 21, 2003 | 10:48 AM
max83's Avatar
I can understand where you say the power levels now may not warrant the use of copper head gaskets. On the other hand though how many of us a year ago thought that there would be a maxima running 11.9's? There seem to be many big changes with the power of the 4th gens. More and more people are building engines. I'm sure we will see people begin to push 400-500 HP.
I do not see where you are coming from with the comment of saying that they are not for street use. As I said before the clamping force should be enough to create a good seal and if you are worried you can all ways O-ring the block.
Old May 21, 2003 | 10:53 AM
SR20DEN's Avatar
VQ Wizard
Have fun.
Old May 21, 2003 | 11:48 AM
Dreizehn's Avatar
Have fun.
Valid arguments.
The head studs sound like a better option.
Old May 21, 2003 | 04:09 PM
max83's Avatar
Originally posted by MadMax95
Valid arguments.
ARP can make the head studs, they have made them for custom applications before. I have the number of someone helpful there if you need it.
Old May 21, 2003 | 04:40 PM
n2oMike's Avatar
The hottest gaskets going right now are from a company by the name of Cometic. They have produced motorcycle gaskets for years, but have recently come out with automotive applications. Their best products are their head gaskets. They have a MLS (multi layer steel) unit that is made from layers of spring steel... and is practically bulletproof. It is used by the biggest names in racing.
Combine these with a set of ARP head studs (best in the business) and you'll be in business.
http://www.cometic.com
http://www.arp-bolts.com
Here's some good head gasket tech.
http://www.krcperformance.com/newcontent/gasketfaq.html
Good Luck!
Old May 21, 2003 | 05:06 PM
ARP studs for top and bottom should be available shortly, its being worked on.
knight_yyz
Nov 1, 2015 01:34 PM
jaydot901
Sep 29, 2015 01:18 PM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
