Ground Control Coil Overs
Old Sep 13, 2000 | 06:29 AM
ericdwong's Avatar
I'm thinking about a set of Ground Control coil overs for my 97 SE. First off, I'm a newbie at coil overs, what is and is not adjustable on these? What should I look for? Also, what is the difference between the GC and the Cattman coil overs? How do you select the correct "spring rate" and stuff like that?
Old Sep 13, 2000 | 12:31 PM
Lordrandall's Avatar
The Cattman system inclues eveything you need to install including KYB-AGX adjustable shox. The GC setup does not include shox.
Old Sep 13, 2000 | 12:42 PM
1MAX2NV's Avatar
The GC is going to be more work ->
First you need to get better struts. Right now Koni is the only logical choice with GC. Next year, KYB/AGX will be even better. The rears are really easy. You slip the adjustable collar on the strut, put the spring on, the top piece and bolt it right up. The fronts are going to be really tricky. You will have to reuse the OEM strut case. This involve drilling and cutting. Not only that. If you want to lower the front as much as possible. You need to cut off the OEM stock perch. Weld a ring around it for the adjustable collar to set on. You don't have to, but I got the rings. Anyway, I still have my GC brand new in the box. I still wonder if I should do it. I might end up getting Sprint Springs. Give me few more weeks to think about it and maybe by then. I will sell you the GC. I believe GC is $399. I was in a group deal for these. You can just pay me what I paid.
CKNY's Avatar
The cattman set is complete with everything you'll need to set up a nice coilover system. It's also about $1000 more. The problem with the GC system is that it doesn't come with shocks so basically you have to choose between the lesser of two evils, Tokico or Koni (if you can find them and even if you can they require alot of work to make them fit). If you know how to do the work or can get someone to do the work maybe you can go GC but if you have the money I would go Cattman.
Again, maybe someone who actually has the GC coilvers can give you more info.
Chris
Matt93SE
May 24, 2019 02:58 PM
95Maxi
35
Sep 2, 2015 10:37 AM
cheftoo
Aug 24, 2015 09:20 AM
