Ordered my ACT clutch today
Old Apr 14, 2003 | 11:49 AM
A-Ron Max's Avatar
Decided not to bother with the lightened flywheel since its too pricey for the gains you get. Are there any other things I should look out for or make sure I get replaced when my mechanic is doing the clutch swap?
Old Apr 14, 2003 | 11:56 AM
Dave B's Avatar
Not DAVEB the parts guy
Gutsy move, Maverick.
Dave
Jeff92se's Avatar
I'm needing a caw
1) replace both tranny output shaft seals
2) replace the pilot shaft bushing(if worn)
3) make DAMN sure to get the flywheel resurfaced and make DAMN sure the flywheel/pressure place is CLEAN before installing.
4) Consider getting the stock flywheel lightened. 3 lbs. makes a little difference and the machine shop needs the unit to resurface it anyway.
5) put synthetic tranny fluid in. Might as well. You have to use new fluid anyway.
6) if you cv boots are torn/worn, now is the time to fix/replace them
Old Apr 14, 2003 | 11:58 AM
Sprint's Avatar
here comes the masses..............
Victim64's Avatar
Re: Ordered my ACT clutch today
So has someone actually posted what gains are "truely" achieved with the flywheel??
Old Apr 14, 2003 | 12:20 PM
ejj's Avatar
ejj
Why is this so important? I've read several writeups that don't specify resurfacing the flywheel, rather just sanding them by hand.
Old Apr 14, 2003 | 12:25 PM
Jeff92se's Avatar
I'm needing a caw
You need a certain type of surface for the new disc to break in on. And with the ACT unit, it's even more inportant. Read the install instructions when you get it. It's very clear they want you to resurface it properly before installing it. It also makes sure the surface is perfectly FLAT. Since the ACT setup has a history of chattering, I'D make this a MANDATORY step. A couple of bucks now is cheap compared to thousands of miles of possible chatter later. It's not 100% that resurfacing will prevent chatter but why risk it?
Old Apr 14, 2003 | 12:38 PM
ejj's Avatar
ejj
Good to know. Thanks.
Old Apr 14, 2003 | 01:12 PM
Requin6's Avatar
Re: Re: Ordered my ACT clutch today
i will in about a 3 weeks i've ordered the Exedy Clutch and Fidanza flywheel...(not looking forward to the install )
--Paul
Old Apr 14, 2003 | 01:21 PM
Victim64's Avatar
Re: Re: Re: Ordered my ACT clutch today
--Paul
Yep, My ACT is sitting in my floor. But my Fidanza flywheel is back ordered??? Who did you order the flywheel from and how much are you paying for it? Think mine is $375 shipped?? Thanks!
Old Apr 14, 2003 | 01:26 PM
A-Ron Max's Avatar
I was considering getting the exedy clutch, but I just couldn't justify buying a clutch that I hadn't heard any reviews about yet. Most guys here say that ACT is the way to go, so thats what I'm getting. I know there are a few horror stories about people busting their trannys, but hopefully that won't be so much of a problem for me since 95% of the time I don't drive too aggresively. I'm just looking forward to being able to chirp my 18's once in a while, and being one step closer to having my car prepped for an NX kit.
Old Apr 14, 2003 | 03:09 PM
96max5sp's Avatar
I was concerned about buying it too but seeing the info on it and having the price at $225 helped sway my decision Now i just have to wait for the flywheel. By the way the group deal is still on until April 24, for the exedy clutch. Plus if you look aroud that clutch is usually around $400.
Old Apr 14, 2003 | 03:35 PM
Requin6's Avatar
Re: Re: Re: Re: Ordered my ACT clutch today
Got it in the group deal from Maxx Tuning USA. $225 for the Exedy clutch, $375 for the flywheel = $600 for the pair.
--Paul
Old Apr 14, 2003 | 04:15 PM
nadir_s's Avatar
vicodin ... gift of life
excellent summary, i never thought of getting the cv boots checked. I am replacing my tranny soon... also gotta put in new clutch. I'll use ure advice.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Excalibur23
Oct 13, 2015 04:33 PM
The Wizard
24
Oct 1, 2015 08:47 PM
