where to buy spacers
Old Apr 30, 2003 | 03:35 PM
avusblue92se's Avatar
Hey I finally got some cash and am ready to buy spacers. Where is the best place to get 5mm h&r spacers? I remember another company that was posted that had the same quality (hub centric and longer studs) spacers but were cheaper. One last dumb question, i can put the spacers on between the wheel and the rotor right?
Old Apr 30, 2003 | 03:40 PM
NickStam's Avatar
did you check tirerack?
Old Apr 30, 2003 | 05:07 PM
yes they don't carry spacers, just the springs.
Old Apr 30, 2003 | 05:12 PM
Xmax's Avatar
Re: where to buy spacers
Yes....and you can try going to www.massimoperformance.com and give them a call....they might be able to get you a set....Cuz a friend of mine went to them and got it. Oh just to let you know that they prolly won't have it on their website.
Old Apr 30, 2003 | 10:58 PM
Nismo's Avatar
got mine from www.optionsauto.com for like $55 for 5mm. yes you first install the longer wheel studs then slide the spacer over them before putting the wheel on
Old May 1, 2003 | 02:36 AM
Kanaka's Avatar
I got a pair from a local auto parts store. they had 7/32" and 7/16" spacers for $18.
Old May 1, 2003 | 07:20 AM
Nismo:
options auto says you have to order the longer studs separately, how much did those run?
Old May 1, 2003 | 08:25 AM
GaMax97GLE's Avatar
Are you trying to clear your calipers or just make the wheels stick out more? Because 5mm not worth it for looks only. With 15mm spacers, H&R supplies new longer studs that need to be installed.
Old May 1, 2003 | 11:15 AM
i need 5mm or 1/4 inches to clear my 300zx calipers.
Old May 1, 2003 | 02:06 PM
Lordrandall's Avatar
I must have posted before the switch.
www.crowautomotive.com
Great product, custom CNC to your specs. Pics of my 5mm and 20mm on my homepage
the 20mm have built in studs.
Old May 1, 2003 | 02:15 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
i have some 5mm spacers that i can sell. By all means they aren't high quality but if you're looking for a cheap solution just PM me.
i have the machined ones from www.crowautomotive.com now so i won't need them.
Old May 1, 2003 | 04:58 PM
Nismo's Avatar
Nismo:
the 5mm H&R supposed to come with the longer studs in the kit, thats what mine had. It was around $55 or so for a pair. If your looking for looks then you need more than 5mm to stand out. I needed 5mm so that my rims wont rub. btw, the cheap universal spacers may cause vibrations and all sorts of junk since they are not hub centric and will just hang on the lugs lop-sided rather than perfectly balanced in the center like the H&Rs. you get what you pay for
Mahmuth
Aug 16, 2024 08:23 PM
Apr 16, 2020 05:15 AM
trsandrew
Oct 25, 2015 02:47 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
