Do I need Camber plates?
Old Jan 21, 2001 | 09:44 PM
Krystian's Avatar
Im planning to lower my car with H&R's. I also want everything to be right, dont want my tires to wear improperly, and my alingnment to be off. Does antyone sell them besides STILLEN? How much do they cost?
Old Jan 21, 2001 | 10:18 PM
buss95max's Avatar
you dont need cambers...h&r's dont go that low..just get an alignment after you lower ur car..
Old Jan 21, 2001 | 10:38 PM
1MAX2NV's Avatar
You really don't need it. A little negative camber->
doesn't hurt. You might want to get the Ingall's camber kit for $40 if you want some flexibility during alignment. It will adjust back 1 degrees.
Old Jan 21, 2001 | 10:46 PM
Krystian's Avatar
Where can I get the ingalls kit?
Old Jan 22, 2001 | 10:52 AM
seven's Avatar
$23 at lightningmotorsports.com
Old Jan 22, 2001 | 11:01 AM
Jeff92se's Avatar
I'm needing a caw
The #1 reason for increased tire wear after lowering is the TOE adjustment(ie.. toe out), not camber. In your case the H&Rs should keep your camber to about 1 neg max. Which is not bad. But when you lower your car is changes the effective end to end length of the tie-rod, which will affect your toe settings to a much greater degree than camber.
Note: If you lower your car so severly(w/o coilovers) to greatly affect the camber, you have probably ruined most of the factory suspension design and will probably start getting alot of funky suspension behavior. Normal driving probably won't make this apparent. The suspension will probably rear it's ugly head in a severe situation(ie...when you need it most)
Old Jan 22, 2001 | 03:26 PM
seven's Avatar
how much lowering do you consider "severly"
Old Jan 22, 2001 | 03:42 PM
Jeff92se's Avatar
I'm needing a caw
Re: how much lowering do you consider
Anything more than about 1.5 inches and I would start having to be concerned about the control arm angles, tie-rod angles and camber settings. At some point, the control arm might start actually getting shorter(effectively) and induce positive camber during severe corning. Which would be a bad thing right? Also at least in RWD(maybe fwd also) bad control arm angles will promote bump steer oversteer in turns where you have to stomp on the brake pedal.
Originally posted by seven
matts95max
Apr 23, 2025 10:44 AM
knight_yyz
Nov 1, 2015 01:34 PM
ricky7780
Sep 24, 2015 06:50 PM
