Trans. temp. gauge info needed
Old May 30, 2003 | 09:26 AM
dmBK's Avatar
How 'bout them cliffs?
i am looking to install a transmission temp. gauge for my auto, and looking for info on how hard it is, what's involved, there to tap (will use electric type gauge), where to place the gauge (besides A-pillar). so if you have one installed, i'd appreciate the info.
Old May 30, 2003 | 09:32 AM
araffio's Avatar
I recently had mine installed by Jeff at Maximum Tuning b/c I was a little apprehensive about doing it myself.
He tapped my tranny pan by drilling a hole and screwing in the sensor that came with the gauge. He put it on the side of the pan so the sensor is not sticking down and can't scrape.
Old May 30, 2003 | 09:40 AM
XXXL Cracker's Avatar
I have my gauge in the glove box..
You can tap the pan or get a manifold which you tap the tranny fluid line with.
Autometer sells both.
Install is pretty straightforward.
d
Old May 30, 2003 | 09:54 AM
dmBK's Avatar
Thanks, guys!
redmaxpa007's Avatar
i SeE what you did therE
d
we installed ours a couple times..
Old May 30, 2003 | 10:38 AM
[maxi-overdose]'s Avatar
Re: Trans. temp. gauge info needed
check my site for more info...page 3 IIRC.
depends on where you want to tap...if you want to tap into the tranny pan....then you dont have to ground the sender. if yout tap the sender into the ATF line with a tee....then you will need to ground it. Tapping the line is easier IMO.
I put my gauges above the AC vent.
Old May 30, 2003 | 12:06 PM
dmBK's Avatar
Re: Re: Trans. temp. gauge info needed
page 6&7, actually
Old May 30, 2003 | 12:18 PM
Re: Re: Re: Trans. temp. gauge info needed
page 6&7, actually
6 and 7 for the gauge....
3 (iirc) for tapping the sender
smplyamzng
Dec 13, 2015 01:19 PM
MichMaxFan
Garage and Workshop
Sep 2, 2015 06:35 AM
TonyJr
Aug 20, 2015 12:14 AM
DayHeyZeus
Garage and Workshop
Aug 16, 2015 12:29 AM
acw
Aug 13, 2015 12:50 AM
