How to get needles off of gauge faces?
Old Jun 1, 2003 | 07:10 PM
KLoWnPR109's Avatar
Do I just pull or pry them off?
Old Jun 1, 2003 | 07:27 PM
Ramius83
No no, don't do that. You got to do this first:
1. Pull the needle stops out first.
2. Turn the needle counterclockwise until you feel resistence in the needle
3. Mark that point, that is the calibration point.
4. Then, keep turning them the same way about 5 revolutions
5. Then, after that, keep turning them and slightly start pulling up on them.
6. After a few more turns, the needle will come off.
You have to be careful not to pull that shaft out, as you know. If you do, you are screwed. Once you get your faces on or whatever:
1. Put the needle back on, on the exact same point that you marked as the calibration point.
2. Turn the needle clockwise and install the needle rest back on.
Old Jun 1, 2003 | 07:40 PM
KLoWnPR109's Avatar
Thanks, but how do you get the needle stops out?
Old Jun 1, 2003 | 07:43 PM
redmaxpa007's Avatar
i SeE what you did therE
a mallot...
Old Jun 1, 2003 | 07:44 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
for the GXE-->SE gauge swap, swapping the odos on the clusters is much less troublesome
Old Jun 1, 2003 | 07:53 PM
KLoWnPR109's Avatar
I decided to take the wise widsom of Addae. Swapping odometers is much easier. HOpefully it works
Old Jun 1, 2003 | 08:10 PM
KLoWnPR109's Avatar
Ok, for the fuel gauge. I've got a 3/4 of a tank but the new gauges had an empty tank. Will the needle "calibrate" itself or do I need to move it to 3/4 myself?
Old Jun 1, 2003 | 08:18 PM
Ramius83
Well, I think that when you plug the cluster in, that the fuel gauge will automatically move up to its position, according to the level of fuel in your tank. If it does not, simply take the cluster out and do what I told you to do in my first post. But this time, instead of putting it back on the calibration point, put it on the 3/4 mark.
Old Jun 1, 2003 | 08:20 PM
KLoWnPR109's Avatar
Ok, thanks for your help!
Old Jun 2, 2003 | 12:52 PM
NJMAX2KSE's Avatar
S_H_I_F_T_
hope this helps.. it worked for me
http://forums.maxima.org/showthread....INDIGLO+NEEDLE
Old Jun 2, 2003 | 01:47 PM
XXXL Cracker's Avatar
It definitely will. I just di this two weeks ago. My gauges now work the way they are supposed to.
I had removed the needles before and I could not get them all right.
Good choice!
D
Miket2006
Mar 1, 2021 03:55 AM
captchaos
Mar 15, 2016 12:18 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
