Advice requested: Coolant flush issues
First off: What is the minimum amount of coolant you can/should run in a car in TX?
I use Toyota Red coolant so I can run extended drain intervals. It's been 2 years and almost 30k, so I did several drain and fills (essentially a flush) this evening. I did all this in my driveway, which has a fairly steep incline so that I could let the water run off during the drain and fills. The last time I flushed the system was at a friends house on a flat driveway, so I just did everything the same.
After 3 drain and fills the water came out clear, so I was ready to fill it back up. I had premixed a gallon of 50/50, so I poured it into the overflow resevoir first and then poured the rest into the radiator. Here's where I believe my problem stems from; since I was working on an incline this time I don't believe as much drained out of the engine as last time. I was only able to fill up the overflow resevoir to the Max line and pour the rest of the 50/50 mixture into the radiator before it started overflowing.
That means that 50% of a gallon of coolant is inside my cooling system. 2/9 quarts = 22%. I don't really need 50/50, but I thought I should run at least 35% or so. I never even considered having less water drain out due to the incline
Depending on suggestions from here I can always drain out a small amount of the mixture and put in pure coolant to bring the percentage up. The problem is that all this needs to happen before tomorrow when I go to work.
The last thing I need are overheating problems.
-hype
Depending on suggestions from here I can always drain out a small amount of the mixture and put in pure coolant to bring the percentage up. The problem is that all this needs to happen before tomorrow when I go to work.The last thing I need are overheating problems.
-hype
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
97_GXE
20
Sep 17, 2015 08:12 PM
Violator
Sep 9, 2015 10:14 AM
