Tinting quest for side and rear windows
Old Jan 27, 2001 | 02:28 PM
GoLdEn MaX's Avatar
Im getting a tint job done on my car on wed and i wanted to post 2 questions. First off the place im gettin it at is the only place near me that does the side windows all the way to the top with no cut off?--Is that ok? Because a lot of the places said they stop the tint a distance before the window ends. Also they are going to do the rear winsheild in 2 pieces and he said u wont tell bc they do it on a defroster line.---Is that ok is it gunna look bad? Thanks for the info guys.
Old Jan 27, 2001 | 04:51 PM
metallic97gxe's Avatar
Master Will
mine are all the way down the door panel was taken off and the whole glass is tinted all the way up and down and my back has four pices if they do it on the defrost line it will be OK...
here is a photoshopped pic of my car shaved,slammed and with my soon to be new rims but the tint is 35% and it is real.....
Old Jan 27, 2001 | 08:11 PM
plrod Black 95 SE's Avatar
the reason not to tint the sides all the way up on our cars is bc the door has a frame around the window. This causes the window to enter into the door sill at the top and creates a rubbing effect on the tint between the sill and the glass. in the long run, this may not be the best setup bc the tint may begin to peel. i've heard of techniques used to combat this problem using adhesives of some type (even clear nail posish)and they may work. IMO there should be at least a slight gap, say 1/4", to insure that the edge of the film is completely set. It may be that the shop that you've found has a technique to deal with this issue. You may want to question them specifically just to be on the safe side.
The two piece back will be fine if they are good installers. I just got a one piece rear window installed in my car; previously had a two piece and my rear glass got busted (halloween prank)
stevesmax
Dec 17, 2020 11:57 AM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
mpbclutch33
Aug 21, 2015 06:09 AM
doctorpullit
Aug 20, 2015 05:15 PM
