Water temp sender location?
Old Jun 18, 2003 | 10:52 AM
Stephen Max's Avatar
Those of you who have installed aftermarket water temperature gauges, where did you put the sending unit?
Thanks!
Old Jun 18, 2003 | 11:17 AM
Chunger's Avatar
My other car is a Hybrid
Old Jun 18, 2003 | 11:20 AM
Originally posted by Chunger
Sender mounted in tube, spliced into hose? Did you use a metal tube or PVC?
Scruit's Avatar
U wanna try me young boy?
That's a pretty sweet install! I retrofitted electric fans on my Bronco and therefore have no location for the thermostat to control them. I'll have to try fabbing up something like you've got there.
Old Jun 18, 2003 | 11:21 AM
araffio's Avatar
I used a T-fitting and put it inline on a hose that's toward the rear of the engine, on the driver's side.
Old Jun 18, 2003 | 11:25 AM
Chunger's Avatar
I used the Omori "adaptor" to hold the sender.
http://www.omori-na.com/catalog/acce...ccessories.htm
Old Jun 18, 2003 | 11:28 AM
Scruit's Avatar
I have a thermostat that is supposed to thread into some location ont he engine. I'll prolly just get a piece of metal pipe that fits tight inside the upper hose (hot water to rad), and get a nut that matches the metal pipe. Then I just drill a hole in the pipe and weld the nut onto it so that the sensor screws into place and is in the coolant flow. As long as I make sure the weld is watertight and the hose is held solid onto the metal tube it should work out just fine.
Right now I just have the fans running constantly... The engine runs waaay too cool all the time and hardly ever gets up to normal temp.
Old Jun 18, 2003 | 11:32 AM
Good stuff! Thanks Chunger.
Old Jun 18, 2003 | 03:24 PM
1MAX2NV's Avatar
Old Jun 18, 2003 | 03:48 PM
Chunger's Avatar
P-173 (36mm) BTW...
They are on sale for $26 on the homepage/overstock...
my03maxima
Jul 28, 2024 07:40 AM
Miket2006
Mar 1, 2021 03:55 AM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
