Removing 5spd differential...
Old Jun 27, 2003 | 09:08 PM
mtrai760's Avatar
'Trynna' is not a word
To anyone who has removed there 5spd differential, does it require any special tools, do you have to re-shim it afterwards? Just wondering. Thanks in advance.
Old Jun 27, 2003 | 09:54 PM
Ramius83
If you remove it, and you do NOT remove/modify the bearings that are already on the differential, then you don't have to re-shim it. HOWEVER, since our trannies come improperly shimmed from the factory, you might as well do it and kill two birds with one stone.
It does NOT require any special tools. To take the actual casing apart, all you have to do is remove the 10+ bolts holding it together. Once removed, just pry the two halves apart. Then just pull the top half up and off the bottom portion. Next, lay the tranny on its side. Have a buddy pull on the two shafts. Wiggling them outwards works the best. While he is doing this, pull out and away on the differential, sliding it out of the tranny casing. Tada, done.........Oh yeah, then cut shims off, put new ones on, re-shim, put back together, etc etc etc.......lololol....;-)
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
ef9
Oct 4, 2015 08:43 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
