what could cut plexglass?...
Old Jan 31, 2001 | 08:37 PM
Ryan93SE's Avatar
im trying to make cleatailights and i think i can do it for the 95-96 tails for limited costs but what do you use to cut plex?..it will be heated up and flexable
Old Jan 31, 2001 | 08:40 PM
Maxstilln's Avatar
A carbide blade should do it.
Old Jan 31, 2001 | 08:41 PM
Matt93SE's Avatar
STFU n00b!
if you do it before you heat it, you can cut it with a router or table saw..
on the table saw, use a very fine tooth blade- like a cabinet grade or plywood blade.
on the router, I dunno. never used one, but it's very common.
don't use a jigsaw, as it will melt the plexi and will "glue" itself back together and harden along the seam before you ever get completely through the plexi. not good.
as for doing it when it's hot and soft, I think tin snips may do the trick.. get some with a curved blade on it. I've seen people cut molten glass with it, but glass is much different to work than plexi.
hope that helps.
Old Jan 31, 2001 | 08:42 PM
tan_camry
A Dremel works for me.
tan
James92SE
142
Jan 2, 2024 09:23 AM
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
