before and after: cutting sprints
Old Jul 14, 2003 | 08:06 PM
global_threat's Avatar
before - regular sprint spring, agx, 19s
now - one coil cut front and rear, agx, 19s
Old Jul 14, 2003 | 08:08 PM
KLoWnPR109's Avatar
That's tite.....
Makes me wanna cut my sprints, but I'm already too low
Old Jul 14, 2003 | 08:10 PM
closeup of f/r gap
front:
rear:
wtf is with the forum lately? i just got errors trying to submit a reply?
Old Jul 14, 2003 | 08:30 PM
Wisky97SE's Avatar
How about a before and after of ride quality and handling?
Your car looks great BTW.
Old Jul 14, 2003 | 08:49 PM
maximadave's Avatar
detailerdaveb@gmail.com
looks tight
Old Jul 14, 2003 | 09:38 PM
willis's Avatar
My heroine
Re: closeup of f/r gap
those close-up pics really make me want to cut my sprints (and get 18's or 19's). like somebody said though, how much worse is the ride, any difference?
wJ
Old Jul 14, 2003 | 11:49 PM
drewm's Avatar
That thing must seriously be riding on bumpstops now. How is the ride by the way?
Old Jul 14, 2003 | 11:59 PM
ch13f's Avatar
Looks really good.. My favorite drop is one where the tires have nearly no gap between the fenders, but I really dislike the tucked look.
Old Jul 15, 2003 | 04:25 AM
njmaxseltd's Avatar
I like the easter eggs in the tree.
Old Jul 15, 2003 | 05:39 AM
92 SE-R 02 SE
looks like a tein drop now..
Old Jul 15, 2003 | 07:39 AM
Dave B's Avatar
Not DAVEB the parts guy
Looks good, but also = NO WHEEL TRAVEL now
Dave
Old Jul 15, 2003 | 08:31 AM
njmaxseltd's Avatar
I hope it's a show only car.
Old Jul 15, 2003 | 09:16 AM
Jeff92se's Avatar
I'm needing a caw
Global, what is the camber like now?
Old Jul 15, 2003 | 10:09 AM
Flava_24/7's Avatar
Boosted Panda
That really does look sweet, but like everyone else I'm wondering about the ride quality. I considered cutting about half a coil in the front on my sprints but was scared of the harsh ride. Do you think this will have any neg. effect on the KYB's?
Old Jul 15, 2003 | 02:04 PM
heh dunno, havn't really checked it...josh said it looked off though, so i'll probably order some camber bolts - 19 inch tires arn't cheap.
Old Jul 15, 2003 | 02:06 PM
thanks guys.
yeah, wheel travel was my #1 consideration when i decided to mod my car
my license is suspended so i havn't gotten to drive it yet, i'm just getting it ready. i rode shotty and it feels a little more bumpy, but nothing i can't handle. when i get my license back i'll definatly beat the **** out of it and tell yall how much it liked it
Old Jul 15, 2003 | 02:40 PM
drewm's Avatar
Originally posted by global_threat
thanks guys.
Well: little suspension travel = horrible handling = stock maxima can probably outhandle you = bigger chance of denting rims = bigger probability of blowing shocks
And if you don't believe me:
http://drewm.dyndns.org/~drew/maxfaq...CuttingSprings
If you wanted to do it correctly, you'd increase suspension travel with something similar to the motivational shortened struts and rear shock mounts, or by going JIC or Progress coilovers. It would improve handling greatly. But as long as you don't care about handling, you've got the best looking setup.
Old Jul 15, 2003 | 02:50 PM
92 SE-R 02 SE
Old Jul 15, 2003 | 02:58 PM
Bad97MaxSE's Avatar
I have a coil cut in the front , and my handling is better not worse....also i bent a rim on the stock setup.
Old Jul 15, 2003 | 03:36 PM
95emeraldgxe's Avatar
looks good, dont blow your struts now :P
Old Jul 15, 2003 | 05:23 PM
GoldMember's Avatar
I have chopped maxspeeds, no problems and have had them chopped for 8 months. Ride is not bad. I have had other org members ride in it with no complaints. It looks like the chopped sprints are lower than my setup though.
Old Jul 15, 2003 | 07:54 PM
blah blah blah
this is a thread about cutting sprint springs. if you don't like it, go away. you and njmax ***** up enough threads with your anti-lowering speech, go elsewhere with it
Old Jul 15, 2003 | 08:10 PM
92 SE-R 02 SE
he is telling you that cutting springs is BAD BAD BAD. Its IDIOTS like you who just dont get it. Be cheap, cut a coil. All the guys with 1/2 brain about suspension will at you
Old Jul 15, 2003 | 08:30 PM
drewm's Avatar
Originally posted by 92 SE-R 02 SE
he is telling you that cutting springs is BAD BAD BAD. Its IDIOTS like you who just dont get. Be cheap, cut a coil. All the guys with 1/2 brain about suspension will at you
It's just a known fact that when you have half as much suspension travel, you need 2x as much spring rate to compensate.
I'm just trying to prevent someone else from getting the wrong idea about lowering cars by cutting springs when they should have gone with stiffer coilovers or increased their suspension travel in the first place.
Like I said, when you're in a corner and your outside rear hits a bump large enough for you to hit bumpstops (which isn't very much in a cut spring case), a lot of weight will transfer off the outside front to the outside rear (just like a really really stiff RSB) and your rear end WILL come out on you. And if you don't know how to control it, it may just end up costing you your life.
I'd rather not see anyone get hurt by taking the cheap way out.
Old Jul 15, 2003 | 08:50 PM
it's a pretty good thing i'm not one of the dumb****s who trying to be a scca wannabe then, eh?
Old Jul 15, 2003 | 09:01 PM
Dave B's Avatar
It's funny, I was just watching a car show last Sunday and they were doing a story on some well-known suspension company over in Europe. They showed them making coil-over kits (real coil-overs) and installing them. The owner of the company said something along these lines, "too many guys think lower is better. They're wrong. Enough wheel travel means everything to superior handling car."
I wish more guys would understand the implications of what they're doing sometimes. It's true that having very little wheel travel is very dangerous and can cause you to loose control.
Dave
Old Jul 15, 2003 | 11:28 PM
drewm's Avatar
Dave
Hit it on the dot. I've actually had the chance to speak to the guy who setup my brother's JICs. His name is Jon and he's a very well respected Road Racer at Willow Springs and Buttonwillow, while also a installer/tuner at Road Race Engineering in Santa Fe Springs, CA. You'll understand that he knows what he's doing after he tunes your car and takes you for a Hell Ride in it, with all 4 of your tires squeeling at every corner.
My brother's Eclipse showed his quality tuning when at Willow Springs with Jon behind the wheel, they easily passed up a 750hp full suspension modified 911 turbo.
Meanwhile another friend of my brother who also had a JIC install from him, lapped everyone in his beginning class, beat all the times of the intermediate class, and posted comparible times with the advanced class at Willow Springs the first time he had ever been on a Road Race Track.
Many of the cars he tunes come out looking quite a bit higher than the owner expected, but after he explains that he has to tune the ride height to have enough shock travel for the specific spring rate never to bottom out in a corner and backs all that talk up with an extreme Hell Ride in it, the owner then understands.
All people that come to him and ask for a certain drop, he turns them away. But then again, people go to him when they want the best handling car in the world, not when they want the lowest dropped car in the world.
Old Jul 16, 2003 | 02:39 AM
nismo2020's Avatar
Needs non-Maxima Friends
looks good
Old Jul 16, 2003 | 03:02 AM
iansw's Avatar
Wow - driving aorund like that in the NW!!!
I fear for your life.....
:P
Old Jul 16, 2003 | 07:59 AM
s0ber's Avatar
I love it looks great.... Wish I could do that but then i'd prolly mess something up like all the others are saying
Old Jul 16, 2003 | 09:51 AM
ny96max's Avatar
i dunno why you would wanna chop the front down anymore the Sprint drop is low enough up front.... but i guess you dont plan on driving with a Stillen lip or new front end with that drop. But if anything you should have chopped the rears 2 coils to level out the Sprints, least thats what i plan on doin when i install mine
Otherwise, looks hott. Keep it up!
Ant
Old Jul 16, 2003 | 12:13 PM
:P
Vancouver/Portland isn't nearly as bad as Seattle
Old Jul 16, 2003 | 12:18 PM
I have a box with three subs and two amps in the trunk...I didn't know how much I would need to cut. Before, it was pretty even. Now with one coil cut f/r, it's uneven
oh well, i'm not cutting another coil off the rear, it's good enough for now
Old Jul 16, 2003 | 02:41 PM
JAY25's Avatar
The car looks great, I believe thats his goal. If others dont approve, who gives a ****, if handling was priority I am sure hed be on other suspension setup. I too have one cut front coil the car rides fine and thats all that matters to me. I can give three shiats about handling since I dont go 120MPH around corners. Everyone doesnt like the same food the same type of women everyone has the right to do what the hell they want with their cars. Life would suck if everyones maxima look the same. I surely dont want my car to look the same w/ the big ooooo gap and uneven drop, I mean thats just me. Not offending anyone just making a point calm down everyone this always happens with suspension threads they go out the window.
Old Jul 16, 2003 | 04:43 PM
drewm's Avatar
That is very true, as long as they know what they are getting in to when they do it. We always just step in to make sure everyone knows the positive AND negative so they can weigh it all for themselves and make a decision that's right for them.
Old Jul 16, 2003 | 06:06 PM
iansw's Avatar
That's true.
I like to get out of Downtown now and then and go to Kirkland just to get some decent roads to rip around on.
Just be careful the next time you come up here for a meet - those bridge connector beams across the road SUCK going into seattle.
Anyway - in case I forgot to say it - it looks awesome!
IanS
Old Jul 17, 2003 | 01:51 AM
HitManSE's Avatar
I was wondering how long til you poped in and said that
Old Jul 17, 2003 | 03:01 AM
I'm not a ****ing scca racer wannabe, if I go fast it's in a straight line most of the time - having "no suspension travel" means about jack **** to me.
yep. if the three or so people who so nicely chimed in don't approve of it, make your own thread and get it stickied or something. I've been here for three years and owned 4th gen maximas all my driving career...I know exactly what I'm "getting myself into."
Dave B, ^ was not meant towards you - I respect and value your opinions. I look up to you, man
James92SE
142
Jan 2, 2024 09:23 AM
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
Taino14
Sep 24, 2015 02:51 PM
