tips for buying used struts.
Old Jul 24, 2003 | 04:14 PM
Battle Max's Avatar
sup everyone ill be picking up a set of used agx for a real good price. Is there any things i can look for to ensure that the struts are in good condition?? they are said to have 6k miles on them
thanks,
Jon
Old Jul 24, 2003 | 05:27 PM
Nismo's Avatar
other than looking for any scratches on the piston rod, I guess you can adjust them to the same rate and compress the piston and watch it slowly move up. do that to both front pair and then back and see if they are moving up at the same rate just to check consistancy.
Old Jul 24, 2003 | 05:38 PM
CandiMan's Avatar
Say Candyman 5 times
Re: tips for buying used struts.
Originally posted by Battle Max V2.0 sup everyone ill be picking up a set of used agx for a real good price. Is there any things i can look for to ensure that the struts are in good condition?? they are said to have 6k miles on them thanks, Jon
That's hard to do. I've seen shocks/struts that look like crap on the outside but it was hard as heck to pull/push the shaft. Then I've seen some the other way around. Buying used shock is a gamble regardless of mileage. Are you buying the struts from a friend (someone you see on a regular basis) or someone from the internet/paper (someone you probably will not see again) maybe that can help you make your final decision.
Old Jul 25, 2003 | 07:41 AM
slizan99's Avatar
make sure to get the KYB warranty info from the seller if you can.
Old Jul 25, 2003 | 07:50 AM
Matt93SE's Avatar
STFU n00b!
Here's three bits of advise on used struts:
1. Don't do it.
2. Buy new.
3. see #1 and 2.
Old Jul 25, 2003 | 08:03 AM
Cutler's Avatar
1. Don't do it.
2. Buy new.
3. see #1 and 2.
Couldn't have said it better myself.....
Old Jul 25, 2003 | 08:11 AM
I30tMikeD's Avatar
I bought used Tokico HP's a while back. It was a well known local org. member so I felt comfortable. when we had my stock struts off it's was easy to tell by compressing them that they were totally shot. The tok's did not act in the same way, they actually rebounded.
So, IMO, buying used struts is on a situation to situation basis. I would probably not buy some from an unkown person that is half way around the country.
Old Jul 25, 2003 | 09:45 AM
hokiemax's Avatar
yes. i30 is right. DONT BUY USED STRUTS unless you know the person real well. and even if you do, with the amount of snow we had and the number of potholes on the whole east coast, I wouldn't buy used struts. who knows what they went through. dont say we didn't warn you.
Old Jul 26, 2003 | 01:06 PM
JAY25's Avatar
KYBs only come with one year warranty, unlike Konis which come with lifetime warranty. I installed used struts on other members cars some busted up on the thread section. So far so good the actual shock was in good working condition.
Old Jul 27, 2003 | 05:46 AM
DARHAW-MAX's Avatar
1. Don't do it.
2. Buy new.
3. see #1 and 2.
Old Jul 27, 2003 | 10:12 PM
WizzaMax's Avatar
I did it and it worked out fine..call em lucky..
the good thing too was the adjuster dials on the fronts were damaged but were replaceable for free thru contacting KYB.
WizzaMax's Avatar
I did it and it worked out fine..call me lucky..
Apr 16, 2020 05:15 AM
Stagnet04
Oct 11, 2015 08:16 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
